It is currently Wed Jul 29, 2026 9:59 pm
Vehicle: 1994 WT Sierra
Post Posted: Mon Nov 19, 2012 8:38 am
Hi guys,
I'd like to replace the oil in the diff's but the plugs look pretty shagged. I'm expecting they will probably be unusable by the time I get them out. Does anyone know where I can get some new ones?
Cheers,
KD.
Vehicle: SJ80, SE416
Post Posted: Mon Nov 19, 2012 9:15 am
Suzuki Shops...
Dealerships...
What model - here is one for a WT Sierra...
http://www.suzistore.com.au/shopexd.asp?id=16
Post Posted: Mon Nov 19, 2012 9:28 am
Enzed / pirtek etc. Thread is 1/2"BSPT
Post Posted: Mon Nov 19, 2012 9:43 am
Never realised they were tapered thread... :?
EDIT: Well I'm sure the fill plug is BSPP. They use a nylon washer for seal.
Post Posted: Mon Nov 19, 2012 10:29 am
1 litre and narrow track are tapered, never looked at a wide track to notice, just assumed it would be the same. A tapered plug will work anyway, bit of thread tape and nip it up.
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Mon Nov 19, 2012 10:32 am
Bunnings... About $1.70 each.
Katherine 2013!
Vehicle: Yellow Ute
Post Posted: Mon Nov 19, 2012 11:35 am
WT drain is the same as 1ltr but fillers are different, I tried to use 1ltr ones in my WT diffs so I would have hex key instead of square, but the filler one is different.
Vehicle: Sj70 tintop
Post Posted: Mon Nov 19, 2012 11:36 am
wreckers should have them.
Post Posted: Mon Nov 19, 2012 1:49 pm
Fritter, could you please tell me where in Bunnings and what they would be called?
KD.
Post Posted: Mon Nov 19, 2012 1:50 pm
Also, any tips on getting them out? Squares are gone.
Post Posted: Mon Nov 19, 2012 2:03 pm
Have you tried a proper 10mm square tool - not a 3/8" drive?
Failing that - welder...
Vehicle: 2002 Suzuki XL7
Post Posted: Mon Nov 19, 2012 2:20 pm
I used a Electric impact wrench from Supercheap cost $46, couple of cracks they came out.
A normal socket driver kept slipping, mines been chewed up bad too, as reubs said can get the tool, the Impact wrench fitted perfect.
Post Posted: Mon Nov 19, 2012 4:14 pm
KD.
In the plumbing section. Just ask for a 1/2 inch bsp. The one's I got have a thin 21mm head on them, so no more messing with the 10mm drive.
Katherine 2013!
Vehicle: 1985 lwb sierra UTE
Post Posted: Mon Nov 19, 2012 5:57 pm
Hamer and small centre punch or chisel carefully tap it around
Post Posted: Mon Nov 19, 2012 10:01 pm
Reubs wrote:
Suzuki Shops...
Dealerships...
Low Range Offroad also sell the Genuine ones, worth getting them to throw in a couple when you next place an order with them:
http://www.lowrangeoffroad.com/index.ph ... plugs.html
Users browsing this forum: Google [Bot] and 353 guests
