It is currently Mon Oct 05, 2026 6:29 am
Post new topic Reply to topic  [ 235 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
Post Posted: Wed Nov 14, 2012 12:01 pm
jrZook - I am talking weak at the spark plug - After I come back from Dubbo I will look further back in the system as you suggest and also test the voltages right through.
Blakey - Yes that is why when you see a spark at the plug when holding it to earth and turning the engine over it does not mean you have a spark when it is under pressure in the cylinder.
Post Posted: Fri Nov 16, 2012 1:55 pm
Hi Guy's and Girl's - I just got back from Dubbo with my great set of new teeth so watch out because now I can BITE :lol:
While down there I called into the Dubbo Suzuki car dealers and had a really nice chat with Bill the nice old'ish mechanic there about this.
He told me some interesting bits and pieces about these engines such as he has seen Timing belts break or tear teeth out but never jump although he had heard that they can if they get ENOUGH oil on them.
He also told me that the coil and igniter on them virtually never play up BUT the distributors all do SOONER or LATER.
The spark should be BLUE and bright and it should be able to jump a 2cm gap at least so that is my problem for sure.
He also tells me you can NOT fix the distributors yourself unless you are a GOOD Auto Electrician with all the right gear - He sends them to Sydney buy it costs a lot and I should try and get a second-hand one first.
So anyone out there got one I can buy PLEASE.............................
Post Posted: Sat Nov 17, 2012 10:11 am
Bump..
Post Posted: Sat Nov 17, 2012 1:09 pm
Got a new one $240 - Tony
Post Posted: Sat Nov 17, 2012 2:33 pm
OUCH, hope it solves the problem.
Post Posted: Sat Nov 17, 2012 3:14 pm
Cheapest second-hand one I could find was $180 so better to get new.
Post Posted: Sat Nov 17, 2012 3:26 pm
It would be frustrating if ya bought a dud one, so I would buy new, too
Post Posted: Sat Nov 17, 2012 3:30 pm
:please: :please: :please: :please: :please: :please: :please: :please:
Post Posted: Sat Nov 17, 2012 4:09 pm
:rofl: Darkhorse - The Suzuki mechanic seemed fairly certain, like 99%, that this was the problem as I had already done the Coil etc and Rinoman thinks it is not the computer so there an't nothing else left :D I hope.
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Nov 17, 2012 7:34 pm
A little off topic, but does he still have the old sierra utes out there?
Post Posted: Mon Nov 19, 2012 8:59 am
Second-hand ones in the yard - I think I saw 3 there.
Vehicle: 92 tintop sierra
Post Posted: Mon Nov 19, 2012 5:40 pm
So is it fixed?
Post Posted: Tue Nov 20, 2012 7:45 am
Waiting for the Dissy to arrive
Post Posted: Thu Nov 22, 2012 3:04 pm
New Dissy arrived in this afternoons mail - Nice and shiny.
It's 41C in the shade ATM so will do the install in the morning .................................. And then go for a drive in it.
I HOPE.
Vehicle: 2002 Suzuki XL7
Post Posted: Fri Nov 23, 2012 8:32 am
Got a few cheer leaders cheering for you.
pompoms pompoms pompoms pompoms pompoms pompoms pompoms pompoms pompoms pompoms pompoms pompoms
Seriously hope the dizzy works..
If not then :deadhorse:
Post Posted: Fri Nov 23, 2012 9:08 am
Thanks Gecko - I got sidetracked as usual so it won't happen till tomorrow now
Post Posted: Sat Nov 24, 2012 8:12 am
Well that worked well - I have a slightly better spark now BUT it seems I now have no fuel being injected - I used my test light at the injector pug again and it barely glows where as it was a good flash before.
The new dissy has four pins in the plug receiver where as the old one has 3 and a blank space however there are only 3 wires on the male plug on the car wiring - As I understand it part of what the computer does is if it does not get a signal it is expecting from the ign system it turns the fuel off and that is what seems to be happening now.
Anyone know anything about this at all?
Post Posted: Sat Nov 24, 2012 8:35 am
Mine only has 2 wires. 93LWBefi
If thats the plug you mean.
Not sure what help that is, though.
Post Posted: Sat Nov 24, 2012 9:04 am
Different all together from the type 3 one on my engine - The wire plugs directly into the side of the dissy - That one looks the same as the 1992 wreak out the back.
Post Posted: Sat Nov 24, 2012 12:03 pm
OK Got fuel again now - turn motor over with no plugs and get a damp/wet patch on my hand when held over the plug holes on all 4 cylinders.
Got a blue spark.
Still hates me :rambo: :rambo: :deadhorse: :deadhorse:
Right now this looks like a great idea - Anyone got a cannon I can hire?
Post Posted: Sat Nov 24, 2012 12:24 pm
I know it's a stupid question, but are you sure the dizzy is timed right? Spent two days trying to get the 1600 in my zook going to find out the dizzy was one tooth out.
Post Posted: Sat Nov 24, 2012 12:27 pm
Timing is done on no.4 plug, unlike many engines
Post Posted: Sat Nov 24, 2012 12:28 pm
It is correct by all the mechanical marks so should at least fire, cough, back-fire or shit itself.
Post Posted: Sat Nov 24, 2012 12:31 pm
It really does not matter which you use (1 or 4) as long as both valves are closed and the piston at TDC the rotor button is then pointing at number lead you are using and then set the rest of the leads accordingly
Post Posted: Sun Nov 25, 2012 1:01 pm
Get someone to crank it while you rotate dizzy advance- retarded to see if it gets any sort of firing happening.
Post Posted: Sun Nov 25, 2012 1:03 pm
And maybe try some 'start ya bastard' too ensure not fuel issue somehow.
Post Posted: Sun Nov 25, 2012 1:21 pm
Refer page 2 :rofl: :rofl:
Post Posted: Sun Nov 25, 2012 2:11 pm
I know I was suggested tony, but have you tried a different battery?
Post Posted: Sun Nov 25, 2012 2:19 pm
:oops:
Went over the whole thread again to refresh my memory.
It dont make sense really. You got fuel, you got spark, you got compression, i assume you have no blockage in the air intake, and i assume no little punk has wedged a peice of fruit in your exhaust!
Post Posted: Sun Nov 25, 2012 2:33 pm
My bet is the timing is 180 out.
Users browsing this forum: No registered users and 98 guests
