It is currently Wed Jun 17, 2026 7:04 am
Post Posted: Mon Dec 17, 2012 7:03 pm
hi guys. having trouble trying to work out why my 1.3l sierra wont idle. if i hold the revs over 2000 it has a slight miss but if i let the accelerator go completely it will splutter and die.. it has new fuel pump, firing through all leads and plugs and ive drowned the carby with carby cleaner and still wont idle. the only weird thing is when number 1 plug is out it idles at 2000rpm... then i put it back in and still wont idle..
Vehicle: Yellow Ute
Post Posted: Mon Dec 17, 2012 7:16 pm
When you cycle the key do you hear a little click around the carb? Sounds like your idle solenoid is playing up.
Post Posted: Mon Dec 17, 2012 7:45 pm
from off to acc to on? or when i start it
Vehicle: Yellow Ute
Post Posted: Mon Dec 17, 2012 8:01 pm
I can't remember if it comes on with the acc or not definitely comes on in the on position though so just move the key from off to on, off to on, its a pretty audible click. You will know it if its there.
Post Posted: Mon Dec 17, 2012 8:06 pm
it clicks on. i can hear and feel it
Vehicle: sj51
Post Posted: Mon Dec 17, 2012 8:11 pm
Blocked idle jet maybe
Post Posted: Mon Dec 17, 2012 8:18 pm
witch is the "brass"? spout looking thing on the front drivers side of the carb? ive sprayed the hell outa that and still nothing. how do i remove it?
Vehicle: sj51
Post Posted: Mon Dec 17, 2012 8:45 pm
Sounds like your talking about the secondary...
I recomend you dont touch your carby if you dont know what your doing
Post Posted: Mon Dec 17, 2012 9:08 pm
its also blowing black smoke. yea i rekon its a job for an expert. wich means sending the carby away as no one in my town touches carbys
Users browsing this forum: Google [Bot] and 70 guests
