It is currently Sat Sep 26, 2026 11:35 pm
Vehicle: 2018 DMAX
Post Posted: Sun Mar 03, 2013 2:41 pm
Ive have just done a head gasket swap on my baleno g16b, having some issues getting it running and wondering if I have the cam pulley set up right. Pulley has two marks, E and I. I lined the pin on the end of the cam up with the slot on E, and then used E to line up to the the mark on the rocker cover. Is this the correct way?
Post Posted: Sun Mar 03, 2013 2:48 pm
Its E on a 16v Vitara so ill assume yes
Vehicle: 2018 DMAX
Post Posted: Sun Mar 03, 2013 3:02 pm
Ok, that's good. Problem is elsewhere.
Vehicle: 2004 Jimny 1.6
Post Posted: Sun Mar 03, 2013 4:28 pm
It's the E 100% what is the engine issue? Was the cam removed by any chance?
Vehicle: 2018 DMAX
Post Posted: Sun Mar 03, 2013 5:49 pm
Cam needed to be removed to get the head bolts out.
I have spark and fuel. Turns over fine but struggles to fire, it sounds like a timing issue to me when it turns over, but I have tried the dizzy in every conceivable position. This is what made me wonder about the cam pulley.
I need to find the check engine light wire (bloody dash out job) and see if any codes come up.
Post Posted: Sun Mar 03, 2013 11:01 pm
Just a quick one. I had a similar issue. Check all your rocker arms and make sure they are located correctly over the valves. They have a nasty tendency of not sitting directly on top of the valve head.
Just a thought. And it's a quick check
Users browsing this forum: Google [Bot] and 104 guests
