It is currently Sun Nov 01, 2026 6:50 pm
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Mar 03, 2013 9:02 pm
What methods do u guys use to cut the 25mm holes in the chassis for the tcase lift
Vehicle: '96 LWB trayback
Post Posted: Sun Mar 03, 2013 9:06 pm
Why do you need to cut holes in the chassis to lift the transfer case?
The first time I lifted mine, I used blocks, just like body lift blocks between the chassis and the original rubber mounts. It's a bolt on/bolt off solution.
Post Posted: Sun Mar 03, 2013 9:09 pm
25mm/1" hole saw. :?
Post Posted: Sun Mar 03, 2013 9:13 pm
What he said 8O
Post Posted: Sun Mar 03, 2013 9:35 pm
What he said
:roll: I'm using justcruising 's tcase lift,
Not as stupid as it sounds.
Post Posted: Sun Mar 03, 2013 9:37 pm
And a 25mm hole saw has a 7mm drill for the pilot hole the factory hole is about 10mm ,see my drama
Post Posted: Sun Mar 03, 2013 9:42 pm
25mm drill bit..
Post Posted: Sun Mar 03, 2013 9:51 pm
A good idea but not feasable or pratical in my case. Not taking the piss out of ur idea or u I swear.
But most 25mm drills are Morse taper
Post Posted: Sun Mar 03, 2013 9:54 pm
stepped drill bit. :?
Post Posted: Sun Mar 03, 2013 9:57 pm
That's not a bad idea atari4x4, ;)
Post Posted: Sun Mar 03, 2013 10:04 pm
Just_Cruizin should have supplied you a rod to slip into the hole. That's if I assume you got a full kit off him?
Post Posted: Sun Mar 03, 2013 10:06 pm
I didn't notice one but I will double check tomorrow thanks Bruce
Post Posted: Sun Mar 03, 2013 10:34 pm
When I put mine in I just had to drill the holes big enough to fit the crush tubes
Post Posted: Sun Mar 03, 2013 10:36 pm
Ken, I can drop off one this week if need be. Greg
Post Posted: Mon Mar 04, 2013 5:19 am
I have a step drill if you need it Ken, they're pretty expensive for what they are
Post Posted: Mon Mar 04, 2013 7:39 am
Im happy to pay for it or even come pick it up I don't rember seeing 1 but I probably just lost it lol.
Ill see if it works out logisticaly with Greg first. But thanks any way mate .
Vehicle: Getting parts atm
Post Posted: Mon Mar 04, 2013 2:39 pm
U can buy a cheap stepper drill from bunnings, they are actually alright, I been drilling 6mm plate done bout 20 or more holes and still sharp, was bout $16 for set of 3
Post Posted: Mon Mar 04, 2013 3:01 pm
I used a cheap step drill from SCA to drill holes in my leaf springs. I snapped the end off it but it went pretty well!
Vehicle: 86 SJ413 dings / rust / 30's
Post Posted: Mon Mar 04, 2013 3:06 pm
turn down a 10 dia drill or whatever you need to the size to fit in your hole saw (Prob something imperial) eg a stepped shank drill...... all of 10min in a lathe
25 mm drill bit going through a 10mm hole in a run of the mill hand drill will "tweak" your wrists when not if it bites :D
Post Posted: Mon Mar 04, 2013 4:32 pm
Oh yes, hence is why I now recommend the hole saw
Post Posted: Mon Mar 04, 2013 8:04 pm
Yer man I was originaly going to just turn a 10mm drill bit down but got stuck working at place with no lathes but with just_cruising drooping off the thin tube to slide over the drill bit problem solved ;)
I think I might have a look at bunnings for the step drill thou sounds cheap
Vehicle: 1997 Sierra SJ80
Post Posted: Mon Mar 04, 2013 10:21 pm
25mm hole punch?
Only good if there is a large hole nearby to insert smaller half in, which I had, but my hole was on a different vehicle.
Post Posted: Tue Mar 05, 2013 7:10 am
Here is the solution Image
Post Posted: Tue Mar 05, 2013 10:39 am
some times the easiest solution is the best.
Post Posted: Tue Mar 05, 2013 5:17 pm
Seems to be ;)
Post Posted: Tue Mar 05, 2013 5:21 pm
i reckon you should still buy a stepped drill bit, bloody handy to have. :wink:
Post Posted: Tue Mar 05, 2013 5:31 pm
Yer for sure id use one heaps
Post Posted: Tue Mar 05, 2013 6:12 pm
Apologies, when you said you were drilling holes in the chassis I assumed you ment the chassis not the brackets the TC mounts to ;)
Post Posted: Sat Mar 09, 2013 6:11 pm
I was like wt lol all good buddy
Users browsing this forum: Google [Bot] and 389 guests
