It is currently Sun Oct 04, 2026 9:28 am
Post Posted: Fri Mar 15, 2013 8:26 pm
Just putting new suspension bushes on my sierra. The kit comes with a little bag full of white grease/lube. Do i put this on the outside of the bush where it rubs against the spring and the chassis or on the inside where it rubs against the bolt, or both?
Vehicle: MG410
Post Posted: Fri Mar 15, 2013 8:31 pm
General consensus = dont use at all
Grease attracts sand. Sand + rubber + moving parts = bad
Vehicle: SWB Sierra
Post Posted: Fri Mar 15, 2013 8:53 pm
I don't know who General Consensus is, but I disagree.
Poly bushes get greased.
Rubber don't, but a small amount of the correct type of grease makes assembly so much easier.
Post Posted: Fri Mar 15, 2013 9:27 pm
quoted for truth cause i'm not the general consensus.
Post Posted: Fri Mar 15, 2013 9:35 pm
I'm with Matthew on this - if they are polyurethane, grease them on the inside where the bolt passes through.
Vehicle: MG410
Post Posted: Sat Mar 16, 2013 2:46 am
Poly is a poor choice IMHO
Rubber all the way
Post Posted: Sat Mar 16, 2013 3:38 am
Rubber is standard OEM because it's cheap and it works, but almost every aftermarket suspension vendor either supplies poly as standard practice or offers it as an option - is there something they know that you don't?
Personally I would say they both have their place.
Vehicle: LWB Sierra & XL7
Post Posted: Sat Mar 16, 2013 6:16 am
Yep, Like say, to be used as suspension components? :wink:
I used rubber bush's and smeared any parts that touch each other with rubber grease.
'92 Vitara & Camper trailer
Vehicle: '96 LWB trayback
Rubber all the way
I'm sure Bruce will chime in here eventually as our resident poly guru.
Poly isn't Poly. The various grades can have a huge impact on performance and longevity. Just because you've had a bad experience with Poly bushes it would be very remiss of you to write them off entirely. They're a perfectly practical, durable and well performing solution if you use the correct ones for your intended usage.
Post Posted: Sat Mar 16, 2013 6:41 am
Thanks for the info guys
Post Posted: Sat Mar 16, 2013 8:13 am
Rubber all the way
can you find me a full set of replacement bushes that aren't poly for the calmini 3" vitara lift?
Post Posted: Sat Mar 16, 2013 8:38 am
Correct Matthew.
Post Posted: Sat Mar 16, 2013 9:54 am
General Consensus outranks Major Problem, and both outrank Captain Obvious, but Captain Obvious says use Castrol LMM grease on inner and outer surfaces of Poly bushes, and soapy water only to fit Rubber bushes.
Do this, or Corporal Punishment will come down hard on your Privates.
Post Posted: Sat Mar 16, 2013 10:17 am
:peaceout: :peaceout:
Vehicle: MG410
Post Posted: Sat Mar 16, 2013 11:59 am
harsh, brittle and 4x the price. any more benefits for poly?
Post Posted: Sat Mar 16, 2013 12:07 pm
You missed this post :wink:
Post Posted: Sat Mar 16, 2013 12:09 pm
They don't have to be harsh or brittle. I've fitted some bruce bushes (I think they were from bruce) and they are approximately as soft as rubber.
I haven't put any driving on them so I can't comment on lifespan, but they're certainly soft.
Post Posted: Sat Mar 16, 2013 12:38 pm
I got the same performance, flex and comfort wise, out of both Suzistore rubber and Bluemax poly but the poly ones lasted about 3 times as long.
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Mar 17, 2013 7:16 am
Does Bruce still have some of these bushes?
Post Posted: Sun Mar 17, 2013 8:06 am
Pm him :wink:
Post Posted: Sun Mar 17, 2013 9:19 am
I had Bruce make me poly bushes so soft I could make the fixed end of the spring twist till it touched the bolt :)
Pink too
Post Posted: Sun Mar 17, 2013 10:00 am
Ive had zero issues with poly.
Its only when you jam a shackle into the rocks that you peel off a bit of the mushroomed part, but you get that ;)
Post Posted: Sun Mar 17, 2013 10:54 am
Pink too
:woohoo: I might pm him about some pink ones :D
Users browsing this forum: No registered users and 187 guests
