Suzuki does not spec the pressure at idle - the FSM calls for 46.9~61.1 psi @ 4000 rpm with the engine warm - from experience anywhere between 20~25 psi at idle, depending on how hot the day is, how hot the engine is and your idle rpm.
Users browsing this forum: No registered users and 223 guests
