It is currently Thu Jun 18, 2026 12:31 am
Vehicle: 2009 Jimny Sierra Manual
Post Posted: Sat Jul 06, 2013 6:54 pm
Started installing the UHF into the Jimny today (amazing how long it takes to do simple jobs when you have to keep 1 eye on a 2 year old running around the place)
Everything is mounted, i just need to get power to the UHF unit now, i have elected to not use the crappy, short cabling that came with the unit, as i am not wiring into the 12v socket on the dash. I am going to wire direct to the battery then earth to the body, as i want to be able to use the UHF with out having to have the keys in the ignition.
Whats the best gauge wire to use, would 2 core, 3mm sheathed trailer wire be sufficient or should i run 2 separate 1 core 4mm wires? The twin core is 10 amp and the single cores are 15 amp
Either / or isn't a problem as i have both readily available. Obviously i will be running an in-line fuse (10A) close to the battery.
All advice and recommendations appreciated as wiring is not my strong point..
Post Posted: Sat Jul 06, 2013 7:15 pm
A UHF radio uses approximately no power. I think they have about a 2A fuse on them or something, and even that is more than double their normal consumption. The "crappy" cabling is more than enough.
Personally, I wouldn't wire to constant on- you will leave it on and flatten the battery eventually, but each to their own. I'd wire to An ACC circuit if it was me- like the cigarette lighter.
Post Posted: Sat Jul 06, 2013 7:17 pm
This
Post Posted: Sat Jul 06, 2013 7:22 pm
This
That.
Post Posted: Sat Jul 06, 2013 7:25 pm
See thats why i asked the question. Thanks guys.
I'm open to all advice from people with more technical knowledge than me. I cant imagine leaving the unit on, surely the backlit display would be a give away?
Anyways i'll go into the 12v socket if thats what is recommended as best. Should i earth to the body or to the negative in the 12v socket?
Post Posted: Sat Jul 06, 2013 7:35 pm
Either earth is fine.
Is there any point to having constant power for a UHF?
Post Posted: Sat Jul 06, 2013 7:38 pm
I left my cb on in my oll Moke one night, it frightened the crap out of me,
it was parked close to my bed room, and loud voices started in the middle of the night.
Since then have always wired to the acc circuits.
Post Posted: Sat Jul 06, 2013 7:43 pm
Excellent, thanks chaps.
This thread can be locked now
Post Posted: Sat Jul 06, 2013 7:52 pm
Someone else may want to comment so it can stay open
Post Posted: Sat Jul 06, 2013 7:57 pm
lock it, why? think someone's a bit trigger happy these days :rofl:
:beer:
Post Posted: Sat Jul 06, 2013 8:01 pm
i'll get back in my box and pipe down now... :D
Post Posted: Sat Jul 06, 2013 8:12 pm
You'd be surprised. I reckon everyone who has wired an override switch to turn off their thermo fan for water crossings has forgotten to turn it back on and overheated their car. I did the same with a manual switch for my water pumps.
Rule of thumb- if there's a way you can throw a switch and wreck/flatten/overheat/burn out something, you will.
Post Posted: Sat Jul 06, 2013 8:14 pm
I have to agree with that actually!
Post Posted: Sat Jul 06, 2013 9:12 pm
I have always wired UHF to a constant on in case of emergency, don't need keys to yell for help. As that's what I'm used to I just cast an eye to it before I leave the car
Vehicle: 1994 Suzuki Sierra soft top
Post Posted: Sat Jul 06, 2013 11:10 pm
Always wired to constant you know when it's on and when it's off you can't forget unless it doesn't have a led screen you won't forget
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Sun Jul 07, 2013 8:07 am
Im going to install a couple of constant powered accessory sockets in the zook for camping, but they will go through one of these
http://www.kemo-electronic.de/en/Car/Mo ... 2-V-DC.php
Post Posted: Sun Jul 07, 2013 9:42 am
As I said, each to their own. I park my car in the shed for longish periods - it might be weeks before I look at it again. My CB isn't in plain sight when I look in the vehicle so it's easy to leave on inadvertently.
Post Posted: Sun Jul 07, 2013 12:48 pm
i agree if it can be left on it will be, i have left my interior light on a few times and the buzzer has saved me from leaving on head lights more times then i can count.
Users browsing this forum: No registered users and 197 guests
