It is currently Thu Oct 01, 2026 4:24 pm
Post Posted: Sun Oct 06, 2013 1:52 pm
Hi all I have just picked up a new Sierra and its got led blinkers all round, there all working but are blinking fast,
How do I fix this, I have 2 12v resistors at home but not sure where to wire them in. Or am I better to change the blinker unit under the dash.?
Post Posted: Sun Oct 06, 2013 1:55 pm
IMHO change the blinker unit - quicker and easier than wiring resistors into everywhere.
Post Posted: Sun Oct 06, 2013 2:42 pm
The resistor gets attached across the light (one side to positive, other to negative) but as Steve suggested probably easier to switch flasher cans over
Vehicle: 96 vit hardtop
Post Posted: Sun Oct 06, 2013 6:03 pm
Yeah sounds like you're using a normal flasher. Get an LED flasher. Will just work.
Post Posted: Tue Oct 08, 2013 7:29 pm
I bought an led flasher can from an auto elec for $25, they even fitted it for free.
Vehicle: Drover pickup turk
Post Posted: Fri Dec 02, 2016 1:01 pm
Didn't want to create a new thread, So I'll add to this.
Changed my rear taillights to LED units, blinker is now fast. No worries I thought and ordered a LED flasher can/relay off eBay.
Installed and tested with ignition on but engine off, blink rate is fine. Start engine and blink rate is fast again, WTF? Voltage issue?
I like the tuna here
Post Posted: Fri Dec 02, 2016 2:07 pm
Nevermind. Found the one out of my donor baleno and filed a certain little 'hoop' that's inside the can to reduce the flash rate. Maaad.
Users browsing this forum: Google [Bot] and 97 guests
