It is currently Fri Oct 09, 2026 10:29 am
Vehicle: Suzuki sierra SJ70
Post Posted: Fri Sep 20, 2013 8:29 am
Hi,
Can anyone tell me if a ARB type bull bar off a 1987 Suzuki Sierra SJ50 will bolt on to a 1995 Sierra SJ70 model without modification. Are the chassis mounts the same.
Online
Post Posted: Fri Sep 20, 2013 11:05 am
Yes. 100% bolt on.
Post Posted: Fri Sep 20, 2013 11:53 am
I thought it would, I was told it would not fit.
Thanks Steve
Vehicle: 95 Leafy Sierra
Post Posted: Mon Oct 07, 2013 10:15 am
Hijacking but staying on topic....
Bought an arb bullbar from a guy on the forums, but can't get it mounted.
Mounts are on the outside on chassis rail but the leaf spring mounts are in the way and don't allow the bracket to sit properly.
Really weird as the previous owner had it mounted on an sj70 too.
Pics so you guys can understand what I mean:
Halp me pls
Vehicle: SWB Sierra
Post Posted: Mon Oct 07, 2013 10:42 am
The lower section of the bar mount goes inside the chassis rail.
Post Posted: Mon Oct 07, 2013 10:48 am
So upper mount goes inside and lower mount on the outside???
Got any pictures? More of a visual guy lol
Post Posted: Mon Oct 07, 2013 10:59 am
What?? :?
Post Posted: Mon Oct 07, 2013 11:02 am
kritas wrote:
So upper mount goes outside and lower mount on the inside of the chassis???
Online
Post Posted: Mon Oct 07, 2013 11:26 am
That bar has been modified. (Slightly) possibly to reinforce the mounts due to removal of the outriggers. Matthews comment is correct IMHO.
Vehicle: SWB Sierra
Post Posted: Mon Oct 07, 2013 11:29 am
Post Posted: Mon Oct 07, 2013 7:59 pm
Yeah I got the work done to reinforce the mounting points because I bought the bullbar with bent mounts and they were weak.
That last picture is perfect, explains what I need to do with my 2inch bullbar lift bracket(match body lift)
Thanks for insight guys, appreciate it
Vehicle: Suzuki Sierra 1996 SJ80
Post Posted: Fri Jan 10, 2014 1:01 pm
Hey guys.
Will a leafy bullbar for a coily zook?
Like are the mounting points the same?
Thanks
Vehicle: SJ80, SE416
Post Posted: Fri Jan 10, 2014 5:18 pm
Bozy97 wrote:
Hey guys.
Yes, will fit. Will be small gap between bar and body under each headlight.
Post Posted: Fri Jan 10, 2014 6:30 pm
Will there be gap with calmini bar?
And do you know if rear bars fit aswell
Users browsing this forum: No registered users and 77 guests
