It is currently Mon Aug 03, 2026 6:03 pm
Post Posted: Wed Oct 02, 2013 5:12 pm
Got some bad news...
I need a New Steering Rack for the XL-7..
Had my 5000k check up on the Dobinsons Lift kit and they found my steering rack to be leaking pretty badly..
So I am hunting around for a new steering rack/ Reconditioned Steering rack.. I just have no Idea where to be looking..
Ebay has heaps of American Steering racks but I am pretty certain they wont fit due to having the steering on the incorrect side of the car !
Post Posted: Wed Oct 02, 2013 5:29 pm
Try power steering conditioner, fixed my leak for nearly 3 years, before needing another dose. I used Moreys, very happy. People seem happy with nulon as well. It replaces the fluid, and normal fluid can be used for top ups.
Worth a try. Or try sourcing the seals.
Post Posted: Wed Oct 02, 2013 5:35 pm
England is rhd here some seal kits http://steeringseals.com/kits/manufactu ... -kits.html
Findapart is useful if you do need a rack http://www.findapart.com.au/suzuki-wreckers.php
Post Posted: Thu Oct 03, 2013 5:59 am
Yeah its leaking pretty bad from the Input shaft seal.. Last thing I need is it letting go entirely..
Post Posted: Sun Oct 06, 2013 8:23 pm
Just tried replying to Vits93 but I am Not sure he got my message !
I am after a Steering Rack thats in good condition...
I really need one from a 2001-2003 XL-7 as I am not sure if the ones from a Normal GV will fit it..
Post Posted: Mon Oct 07, 2013 11:36 pm
XL-7 and GV steering racks are the same.
I just fitted a steering rack from an XL7 into my 2001 GV and they were identical. 8)
Post Posted: Mon Oct 07, 2013 11:59 pm
Just be aware - there are two different RHD racks - which were used on both GV & XL-7 - so yes - you can use an XL-7 rack on a GV & vice versa - but you may need to check the rack to make sure you have the correct one.
Post Posted: Tue Oct 08, 2013 8:18 am
Just got a quote to service my existing rack ...
$385!!!! and thats if I remove the rack and drop it off !!!
Post Posted: Tue Oct 08, 2013 8:44 am
That is actually cheaper than I thought it might be (still sucks though!). They are easy enough to remove so shouldn't take you too long.
Remember to factor in you will want a wheel alignment once it is all back together also.
Post Posted: Tue Oct 08, 2013 11:41 am
Yep I will definately get a wheel alignment done when its fitted back up..
I am trying Wreckers to see what a 2nd hand one is worth ..
Post Posted: Thu Oct 10, 2013 9:26 pm
Last i check a second hand one from the wreckers was worth about $300-$400 anyway. So i think you're better off pulling it out and getting it rebuilt
Post Posted: Fri Oct 11, 2013 10:03 pm
Oh.. That price isn't for a Rebuild.. its for replacing of 1 seal on the damned thing...
So still hunting an alternative
Users browsing this forum: Google [Bot] and 12 guests
