It is currently Sun Nov 01, 2026 2:44 am
Vehicle: 1985 lwb sierra UTE
Post Posted: Thu Oct 24, 2013 9:41 am
Hey guys does anyone know off the top of there head, what thread the brake bleed nipples are ???
The reason I ask is im keen on getting some self bleeding ones and they want to know the size ....some help would be appreciated :)
Post Posted: Thu Oct 24, 2013 9:48 am
M10x1.0mm from memory.
Post Posted: Thu Oct 24, 2013 5:25 pm
It's a 10mm hex head, I did battle with mine last night. Thread size above would be close
Post Posted: Fri Oct 25, 2013 8:56 am
http://www.lowrangeoffroad.com/index.ph ... eders.html
As much as they're a cool idea, they hardly seem worth it to me. At most you're probably going to bleed the brakes half a dozen times in the time you have the car. They don't achieve anything a normal 1 man brake bleeder wont, they cost just as much and they're only applicable to one vehicle.
Vehicle: WT sierra, GU CRD
Post Posted: Fri Oct 25, 2013 9:29 am
Isn't the service interval for brake fluid one year?
But agree with your statement other than that.
I love ZD30. :)
Post Posted: Fri Oct 25, 2013 3:30 pm
You're meant to replace the fluid every 2 years.
I'm sure all AZers follow the maintenance schedule religiously. :D
Post Posted: Fri Oct 25, 2013 3:31 pm
im sure mine have never been changed in any car
Post Posted: Fri Oct 25, 2013 4:06 pm
And people complain about sierra brakes. :?
I've bled through an entire bottle till new stuff comes out, but never actually set out and said : "I'm gunna change the brake fluid today" so can't talk either.
I love ZD30. :)
Post Posted: Fri Oct 25, 2013 4:29 pm
and do we know why they recommend to change it regularly? :?
i only remember this cause the old man spat it at the mazda mechanics that serviced ones of mum's mazda's in the late 80's & left the cap of the master cylinder, not only splashing brake fluid everywhere but for the fact that brake fluid absorbs water (hygroscopic)... the old boy made them flush/bleed the system & got a few free services out of them back in the day. :lol:
wiki says this stuff wrote:
(DOT 3, 4, and 5.1) brake fluids are hygroscopic (water absorbing), which means they absorb moisture from the atmosphere under normal humidity levels. Non-hygroscopic fluids (e.g. silicone/DOT 5-based formulations), are hydrophobic, and can maintain an acceptable boiling point over the fluid's service life, although at the cost of potential phase separation/water pooling and freezing/boiling in the system over time - the main reason single phase hygroscopic fluids are used.
Post Posted: Fri Oct 25, 2013 4:35 pm
Basically my understanding is it goes spongy (pedal feel) and allows the system to deteriorate internally (corrosion), due to the fluid taking on water.
Basically what you have referenced. The Holden stealership here claims they change it every service due to the humidity up here, to me that sounds like bunk. But my brakes were definitely firmer after I got it back.
Its like 8 bucks a bottle for brake fluid.
edited in: "pedal feel" and a spelling mistake
I love ZD30. :)
Vehicle: 91 tin top
Post Posted: Fri Oct 25, 2013 5:42 pm
it would have to be pretty bad for it to feel spongy. Its recommended every 2 years, some cars have it as part of the scheduled services (Kias all have it every 30k/ 2 years)
at work if its not part of the service you can tell if it needs a flush if the master cylinder res has what looks like algae/slime on the inside above the fluid line.
Users browsing this forum: No registered users and 88 guests
