It is currently Tue Oct 27, 2026 2:19 pm
Vehicle: 2005 Suzuki Jimny JLX
Post Posted: Wed Dec 25, 2013 3:14 pm
Hi,
I've just bought a Sony WX-GT90BT headunit and want to install it in my 2005 Jimny (newer style dash). The radio plug in my jimny has been cut off already by a previous owner. Can anybody tell me what colours in the car need to be connected to the colours from the stereo.
The headunit colours are:
Yellow (Battery +)
Red (Acc +)
Orange/White (Illumination)
Black (-)
Blue/White. (Rem out)
SPEAKER COLOURS
White (Front left +)
White/Black (Front left -)
Gray (Front right +)
Gray/Black (Front right -)
Green (Left rear +)
Green/Black (Left rear -)
Purple (Right rear +)
Purple/Black (Right rear -)
The Jimny colours are:
Black
White
White/Black
Red/Yellow (Illumination)
SPEAKER COLOURS
Blue (Front left -)
Blue/Black (Front left +)
Red/Green (Front right -)
Red/Black (Front right +)
Light Green/White Rear
Light Green/Black Rear
Gray/White Rear
Gray/Black Rear
I have the speaker wires all connected but the headunit will only turn on when all other wires (except rem out wire) are connected. Therefore the headunit is not holding memory. It will always revert back to demo mode. Anyone able to help?
Post Posted: Wed Dec 25, 2013 3:41 pm
Do you have a test light or multimeter? If not then it might be a good idea to grab one tomorrow
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Dec 25, 2013 5:29 pm
White is constant and white/black is acc
Post Posted: Wed Dec 25, 2013 9:30 pm
Yeah I have both but didnt give me any readings. I think I may have blown a fuse.
Post Posted: Wed Dec 25, 2013 9:31 pm
Thanks for that Jimny_Timmy, will have a go at wiring it up that way tomorrow.
Post Posted: Wed Dec 25, 2013 9:34 pm
Do I connect the black cable (from my Jimny) to the black cable from the headunit? It had a little connector on the end and the book says earth it to the car. Can they just be connected together?
Post Posted: Thu Dec 26, 2013 2:31 am
Yep :)
Post Posted: Thu Dec 26, 2013 6:02 am
jimny_timmy wrote:
Yep :)
It's better off going straight to a metal part of the dash, otherwise it can overload the circuit and blow the tail light fuse
Post Posted: Thu Dec 26, 2013 7:12 am
light green pair is rear left, grey pair is right.
Post Posted: Thu Dec 26, 2013 7:21 am
Scrawn wrote:
jimny_timmy wrote:
Yep :)
jimny_timmy wrote:
Yep :)
Thanks for the help. I will replace the fuse today and give it another go.
Post Posted: Thu Dec 26, 2013 7:02 pm
Well I've now fixed the headunit. To save time from trying connect the two wires I reconnected the plug to my Jimny and then bought two wiring harnesses. One Suzuki/Honda to ISO, and the other ISO to Sony 16 pin. Connected them but it still didnt work. Checked fuses under my dash and the Radio Dome fuse was blown as well and the Cigar fuse. Replaced both and now works perfectly. Thanks for all your help, really appreciate it.
Users browsing this forum: No registered users and 171 guests
