It is currently Sun Nov 01, 2026 8:21 am
Post Posted: Mon Apr 14, 2014 2:53 pm
The time has come to move on from my Jim, just sits in the driveway and the batteries have both failed (been that long) so I let the rego lapse and now I am going to part it out. I would prefer to at least get a deposit for the motor first before I start to take stuff of that will make the car undrivable.
But if you have interest in anything, please PM me and let me know. I believe most things are described and if I take them off and they are in less than perfect condition, I will change the description and refund or reduce (buyer’s choice) the price accordingly.
M16a (non vvt) with Heavy duty clutch and Jimny standard gear box. Will bolt into and run on any M13a Jimny (non-vvt) About 55k kms on motor with less than 1000kms of those while been in Jimny Starts at $1400 depending on what add on you need. (fans, alter, rad, started, AC, ect) REDUCED $1200
Super dodgy set of draws (could be improved) with top that could be used as fake floor $70 (NO SHIPPING)
Big Airpump (like $200 tigers one) $50
Jimny Power steering $500
Fake bushwhacker flares, some of the mounts are cracked, covers WIDE tyres for a non – glamour vehicle $100 (put 2 screws in and remove for tracks if you like) (NO SHIPPING)
Jimny Body, Straight diffs minus CVs and Centres ,,and all panels should be available along with airbags and such. Also 2 or 2 ½ (can’t remember) inch zorst is available. There is a complete car there, so if you need anything just ask!
Front Diff centre, with ARB professional installed air locker $1100 SOLD
Rear Diff centre with ARB professional installed air locker $1100 SOLD
ARB new style single Air up pump $220 (once lockers sold) SOLD
Sierra transfer with 6.5 gears professional installed (one bolt hole is cracked open) worked fine for me or would suit re-in forcing ring upgrade has upgrade for jimny speedo also $500 SOLD
Double tough CV’s with Hytuff axles $700 SOLD
Front ARB bar cut to accept low mount Winch and big tyre trimmed $600 SOLD
M8000 Warn winch with cracked housing (works fine as it against the pull, comes with quality rope and a tricky high speed upgrade (reduces overall pulling weight power, great for quick bumps) $350 SOLD
Light force 170s with HID upgrade $180 SOLD
KPD Bead locks with 33/12.5 Bighorns with 75% plus tread $1200 SOLD
Custom rear drive shaft $100 Sold
Front and rear seats Sold
head lights SOLD
Harley in Mulgrave Vic on 0419308610
Post Posted: Mon Apr 14, 2014 4:37 pm
Pm sent.
Where is the crack on the winch housing? Is it on the drum ends?
Vehicle: 2003 Suziki Jimny
Post Posted: Mon Apr 14, 2014 5:30 pm
PM'd for transfer case.
I hope someone buys this as a unit - looks like a good rig.
Vehicle: jimny g13bb, 99 wrx!
Post Posted: Mon Apr 14, 2014 6:38 pm
Interested in those lockers. Maybe even the pump too.
Vehicle: 2000 model Suzuki Jimny
Post Posted: Mon Apr 14, 2014 6:46 pm
pm'd about power steering
Post Posted: Mon Apr 14, 2014 9:04 pm
All PM's Replied!
I remember the winch is just broken at one the the rear bracing sections it has broken off a corner. It is like there has been too much cable spooled on and pushed it out. It looks ugly but doesnt seem to affect the operation at all.
Hey Cal213, give us a call/msg and we can do a deal on the whole lot if you like.
Post Posted: Tue Apr 15, 2014 8:12 am
Pm sent
Vehicle: 98 Jimny
Post Posted: Tue Apr 15, 2014 3:59 pm
pm sent
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Apr 15, 2014 8:21 pm
Interested in splitting the gearbox? If so how much?
Post Posted: Thu Apr 17, 2014 11:31 am
I might try for another week or so to get interest on the both together. I will let you know if this does not happen.
Looks like I have had enough interest in this to start pulling it apart. I will start on Sunday, not looking forward to it :cry: .
I have had Interest on, Tyres and wheels, Both lockers and Bar, winch, drive shaft, Transfer (deposit), gearbox, outside mirrors, flares, pumps, and all axles. And for someone with a keen eye the dual battery kit!
Vehicle: Suzuki Sierra JX
Post Posted: Fri Apr 18, 2014 10:03 pm
Where did you get the fake flares from?
And what's the difference to the original bushwacker flares, in price and the strength of them?
Post Posted: Fri Apr 18, 2014 10:06 pm
How much for the dual battery solenoid??? And what battery's?? If there any good
Post Posted: Mon Apr 21, 2014 10:50 pm
What is custom about three rear tail shaft?
Vehicle: suzuki jimny
Post Posted: Wed Apr 23, 2014 5:53 pm
Have any idea what would be needed to slap that engine into an auto g13bb jimny? And if so would you run me up a kit? Unsure if theres an coupling to join that engine to the standard auto box so probably consider including the box etc...
Vehicle: Suzuki vitara 94 g16a
Post Posted: Wed Apr 23, 2014 6:44 pm
Are you willing to post to 4019 qld for the spotlights
Vehicle: sierra 94
Post Posted: Tue Apr 29, 2014 4:29 am
Sent you a text regarding complete car.
Post Posted: Fri May 02, 2014 3:05 pm
What radius arms do you have on this?
Post Posted: Fri May 02, 2014 4:16 pm
They are just stock ones with caster correction bushes in em. The rear tail shaft is made from scratch as it has the sierra transfer with speedo correction on it. I bent the old one, i am not sure what it was from.
Post Posted: Fri Jun 13, 2014 1:16 pm
do you have an airbox in it ??
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Wed Jun 25, 2014 6:05 am
Pmed.
Post Posted: Tue Jul 29, 2014 9:32 am
Sorry been slack, please PM if you need any parts. There are a few parts that I have not listed and have no idea what they are worth, please pm and we can go from there.
Post Posted: Sat Aug 09, 2014 4:42 pm
Still got a rolling shell with the engine and gearbox in it!
Post Posted: Tue Sep 30, 2014 9:45 pm
Any thing still available??
Users browsing this forum: Xr6_matt and 9 guests
