It is currently Sun Oct 04, 2026 7:29 pm
Post Posted: Tue May 06, 2014 1:36 pm
Hi Guys,
Car threw a code 14 today, which is an o2 sensor fault (by my reckoning anyway). Was wondering if there is anyway to confirm that is the problem without buying an o2 sensor. As I also read somewhere it could also be a coolant sensor fault.
Cheers!
MY BUILD THREAD HERE!!!!!
Vehicle: Suzuki/Sierra/1988 SJ50 HiTop
Post Posted: Tue May 06, 2014 11:10 pm
Check your codes: http://www.rhinopower.org/diag/cel.html
14 is coolant sensor. You might be able to swap coolant and air temperature sensors (if they are the same plug) and see if the fault code changes with the swap.
Post Posted: Wed May 07, 2014 4:31 am
I need to update that page, to make life more interesting for us all Suzuki changed the codes. On an M13 code 14 is O2 sensor heater circuit. If you have a multimeter then you can check the heater circuit resistance, it should be 6.4 Ohms at 20C.
Post Posted: Wed May 07, 2014 9:05 am
Yeah I thought that Page was wrong. Got o2 from the manual. I ordered a new one yesterday, I'll check out the resistance when I get a chance
Users browsing this forum: No registered users and 194 guests
