It is currently Mon Sep 21, 2026 1:12 pm
Vehicle: suzuki sierra lwb
Post Posted: Thu Jul 24, 2014 7:21 pm
Guys ive bought a good second hand radio ( phillips) for the zuke ....wires .....black goes to earth ..... yellow to batery power ...red power wire ...?? What does this conect to ? Could be auxiliary .if so how do I locate that wire ?
Vehicle: 1991 swb vitara JLX
Post Posted: Thu Jul 24, 2014 8:13 pm
think red is power IE from ACC when ignition is on ....and yellow is power all the time ,for memory ect so your radio dont forget stations buy a test light from auto store and probe wires
Post Posted: Thu Jul 24, 2014 8:49 pm
Ok so look for a wire that has power when ignition is off and conect yellow wire to it .
Conect red wire to power wire that is only on when ignition is on
That correct ?
Vehicle: LJ80 Stockman
Post Posted: Fri Jul 25, 2014 7:16 am
Yes that's correct, most aftermarket stereos are wired like that. A handy multimeter will be your friend.
Vehicle: 91 Tin Top
Post Posted: Fri Jul 25, 2014 8:52 am
A simple test light is all you need to find your ACC power for radios.
Put the clip end to earth wire, touch pointy bit on the one you want to test (first with key off, then with key on ACC).
Post Posted: Sun Jul 27, 2014 8:26 pm
Ok all in ...and a good job I must say.
Thanks for your help
Users browsing this forum: No registered users and 151 guests
