It is currently Wed Jun 17, 2026 6:47 am
Vehicle: 1996 Leaf Sierra - Soft Top
Post Posted: Wed Jul 30, 2014 1:28 pm
pompoms
So, I don't know whats the go with me and carburetors but they hate me. All i ever do is give them love and maybe some mud... maybe. but now I have a new issue.
Lately when I am driving around and I get to a slight slope/hill/cliff/driveway/road, anywhere it feels like actually, mainly hills though, (i'm assuming) the bowl of the carby isn't filling up and thus the car doesn't get any fuel and looses all power, though i can pull over and 70% of the time it will still idle. Wait a minute or two and drive off for another 100 meters before it happens again. BUT! :thefinger: If I swing the car left to right going across the road and back, every time the car goes left it launches forward like a spray of fuel is going in...
So this made me think that my float is stuck or not sitting right.
It use to only happen when my tank got to about half full. or maybe that was just a coincidence... :roll:
So I have run a bottle of carby cleaner down it and also through the fuel line going towards the carby but with no luck, problem still persists. Do I need to open up the carby to get to the float/ bowl or would spraying carby cleaner in every spot I can get it into from the top reach the bowl?
Maybe its not the float in the carby? Could my fuel pump be flogged? or anything else you could recommend I try?
8O
Thanks
Thomas :beer:
Post Posted: Wed Jul 30, 2014 1:42 pm
I'd start by replacing the fuel pump these are becoming troublesome as sierras are ageing.
Post Posted: Wed Jul 30, 2014 1:48 pm
Yeah, Just thought it was weird that when I swung the car it got power again for a short burst.
The 4WDProducts on ebay fuel pump any good?? OR could you recommend one to me.
Post Posted: Wed Jul 30, 2014 3:45 pm
Agreed with Gman. Ebay pump should work alright
Post Posted: Wed Jul 30, 2014 4:05 pm
I've been warned away from aftermarket pumps by someone who used to sell them. He only recommended genuine pumps. This is someone who is not shy of selling third party parts.
Post Posted: Wed Jul 30, 2014 5:07 pm
Alright well I picked a non gen one up today for $102 at auto pro.
I'll fit it tomorrow and fingers crossed that's going to fix it!! Never changed a fuel pump before, anything I should look out for?
Post Posted: Wed Jul 30, 2014 5:09 pm
Doesn't need to last too long. Just until I find a Vitara g16b. (If anyone's selling message me)
Vehicle: Vit98 J20A SWB & Sierra89
Post Posted: Thu Jul 31, 2014 1:39 am
If it still plays up, try taking off air cleaner (and centre bolt) warm it up, rev the crud out of it then block the carby with your hand.... leave throttle open as it winds down, then remove hand.... repeat as necessary... it sucks any crud out of the jets.... worth a try, saved me a few times :deadhorse:
Post Posted: Thu Jul 31, 2014 8:26 am
Yeah gave that one a crack before and while I cleaned out the carby with the carby cleaner. Wouldn't hurt to try it again though!!
Vehicle: 1991 swb vitara JLX
Post Posted: Thu Jul 31, 2014 2:30 pm
what about fuel filter... if its blocked ,,you wont get enough fuel...could even be a blockage from the fuel pickup in the tank,had 1 like that in my boat,took ages to find it
Post Posted: Thu Jul 31, 2014 2:43 pm
How would i go about unblocking it from inside the tank if that is the problem? I thought it could be that because i'm using a different tank now i put a hole in my first one.
Post Posted: Thu Jul 31, 2014 3:20 pm
compressed air down the fuel lines. :wink:
Post Posted: Thu Jul 31, 2014 3:28 pm
oh true... Okay if its not fixed tonight ill do that tomorrow at work! Armsup
Post Posted: Fri Aug 01, 2014 6:24 am
Mine started missing bad..Cleaned carby,new cap rotor,leads and plugs...no good. Turned out to be a dirty connection on the wire from the coil.
Do all the easy things first. Wish I had.
bye
Post Posted: Sat Aug 02, 2014 8:31 pm
Okay so new fuel pump in. Continues to happen! I have cleaned te carby but need to pull it apart to focus on the float. May do that tomorrow.
All new leads, plugs, cap and rotor a month ago. I'll check the connections, but definately feels like a fuel problem.
Any more ideas?
Post Posted: Sat Aug 02, 2014 9:31 pm
If you havent pulled apart the carb, you havent really "cleaned" it
Post Posted: Sun Aug 03, 2014 7:07 am
Silly question, but have you replaced the fuel filter? I had similar symptoms and it was fixed by a new filter, I cut the old filter apart and it looked like it had ten years worth of sludge in it.
In particular, my symptoms were going up hills and revving high were impossible, idle and low revs were ok, no acceleration and missing, replaced the filter and revved freely throughout the rev range and no problem going up hills
Vehicle: Sierra
Post Posted: Thu Aug 07, 2014 8:52 pm
Heideisadog wrote:
pompoms
8O
Thanks
Thomas :beer:
This is exactly what happened to mine! :rofl: As i mentioned in the other post check the tank for dents
Vehicle: 92 wt soft top sierra
Post Posted: Fri Aug 08, 2014 4:42 am
Hey mate ive got for sale its oit of a baleno coilpack ignition I believe the engine has done aroumd the 95000km mark comes with ben t kit and most of the parts you need to install it
Chasing around the $1300 ono im in qld toowoomba
Post Posted: Fri Aug 08, 2014 6:23 pm
You have a Pm! :)
Post Posted: Fri Aug 08, 2014 7:43 pm
Perhaps you've got a kink somewhere in the fuel line?
Users browsing this forum: Google [Bot], Google Adsense [Bot], ProteinDrinker, Zook_Fan and 98 guests
