It is currently Fri Jul 24, 2026 12:01 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2
Post Posted: Tue Aug 05, 2014 12:30 pm
Sure- BL's don't compromise suspension behaviour at all and don't raise COG as much as the equivalent suspension lift. A car with 2"+2" can run a bigger tyre with more stability and better handling than a car with 4" of suspension lift.
Post Posted: Tue Aug 05, 2014 1:48 pm
Yep, not for me thanks, I like my up-travel
Post Posted: Tue Aug 05, 2014 1:49 pm
That would be pretty awesome to drive
Post Posted: Tue Aug 05, 2014 1:56 pm
In fact, it would be interesting to run cable ties on your shock shafts to see how much up travel you generally use. I bet it's less than you think.
Post Posted: Tue Aug 05, 2014 1:58 pm
I think more than you think LOL
Vehicle: WT sierra, GU CRD
Post Posted: Tue Aug 05, 2014 3:04 pm
Wasn't Piggles at one stage BL and cut?
Trying to convince my mate to build his up that way, (well in regards to the cut guards and BL, don't need suspension mods, apart from maybe OME or other softish springs and RUF IMO). Infact he could fab as much as he wanted, which coincidentally never seems to be all :lol: .
Realistically I reckon 31s-33s would do the job for a general off road setup here, we aren't building crawlers, need something that retains highway manners and can plug (unfortunately :( ) the mud we have, as well as roughish roads..
I love ZD30. :)
Post Posted: Tue Aug 05, 2014 5:09 pm
Oh, totally- piggles is cut pretty hard. - depending on the tyre size, it's all about bumpstop spacing, BL and lots of cutting. Suspension lift is kept to an absolute minimum.
Post Posted: Tue Aug 05, 2014 8:57 pm
It would be worth the OP having a read of probably the best jimny build thread on here - 31zook's Green Goat. Only 40mm of suspension lift and bumpstop spacing and guard chop to suit 31s would be awesome to drive!
Vehicle: Suzuki Jimny 1998
Post Posted: Tue Aug 05, 2014 9:18 pm
MikeyS wrote:
i have an 8" lift and 32" brand new" bfg muddies you'll neeed much more then a 2"body lift and cut guards to run 32" i have no scrub. also i am running sierra W/T Tcase with 4.9 gearing in it great low range high range is a bit iffy snapping second but 6.5 will be way to reduced for a jimny.i can send you some pics of what i had to do to get no scrub on 32"s
Can you send us some photos through, keen to check out what that much lift looks like on a Jimny!
32s are now on the car, no scrubbing but had to guard chop (alot) but i don't mind the look of it and alot of bashing!!!
Also fitted rear Spartan locker and took it for a test drive over the weekend, BIG difference than standard and really happy with how it performed
Will post photo as soon as i work out how to!?!
Post Posted: Tue Aug 05, 2014 9:23 pm
sign up to photobucket.
Post Posted: Tue Aug 05, 2014 9:36 pm
Post Posted: Tue Aug 05, 2014 9:49 pm
Looks very rigid in the front, still running the anti sway bar?
Post Posted: Wed Aug 06, 2014 7:13 am
Everything still standard with suspension
Vehicle: 91 Tin Top
Post Posted: Wed Aug 06, 2014 7:18 am
Best lines on the front guard chop I've seen so far.
Post Posted: Wed Aug 06, 2014 7:22 am
That looks like less than 8" of lift. Impossible!
Post Posted: Wed Aug 06, 2014 8:01 am
nice work, one of the first jimnys ive seen done "right"
Post Posted: Wed Aug 06, 2014 8:46 am
Yeah that's cool!
Post Posted: Thu Aug 07, 2014 9:48 am
Thanks guys. I am loving the ride height and how it handles off road yeah it lifts wheels but its fun :) . We will probably remove the front sway bar when my husband gets a chance to play around underneath it his been a bit busy with the GU (our long distance toy).
I NEED HELP WITH THESE 6.5 GEARS
Do I need to mod the low range stick to go from the sierra transfer so it works in the Jimny?
Vehicle: 91 Tin Top
Post Posted: Thu Aug 07, 2014 10:13 am
You might find this helpful:
Jimny conversion install
Post Posted: Thu Aug 21, 2014 8:21 pm
Wow..did't know this! 8O
Post Posted: Thu Aug 21, 2014 8:33 pm
if you actually think about it, it seems pretty logical to me...
2" suspension lift + 2" body lift leaves the heavy shit like engine, gearbox & transfer case where it is. = slightly raised COG & 4" suspension lifts all the heavy shit = raised COG
Post Posted: Thu Aug 21, 2014 11:35 pm
Yep. Solves tire clearance issues somewhat for those of us who are welder and thin metal challenged.
Edit: without doing silly stuff like spoa or making sky scrapers.
I love ZD30. :)
Vehicle: Tin Top
Post Posted: Fri Aug 22, 2014 7:33 am
This is going to be COOL 8) !!!
Start a build thread and I am subscribing.
Stance right now looks awesome!
Keep the pics coming in the build thread
:blingbling: :blingbling: :blingbling:
Post Posted: Fri Aug 22, 2014 9:44 am
I run 235s with 50mm lift,if I can get grip I can get out of it/climb it.I run coopers stt mud tires and other than being a shit to balance and noisy on highway good rubber.The point is? I don't agree about gearing on jimny,but then I need to drive mine home at end of play/day.
Post Posted: Fri Aug 22, 2014 10:26 am
so your running 235's with standard gears??..... must feel so sluggish...
Post Posted: Fri Aug 22, 2014 10:27 am
more importantly he thinks coopers are a good tyre!!!
Post Posted: Fri Aug 22, 2014 10:44 am
Coopers are crap.
Why does gearing mean you can't drive it home? :lol:
Post Posted: Fri Aug 22, 2014 12:08 pm
Based on the other thread, where he was wanting a 6 speed gearbox to get the cruise rpm even lower, after fitting 235/75s to his jimny.
I think its safe to assume he currently knows very little about jimnys, gearing and the effects of increasing tyre size.
And he appears arrogant enough to think suzuki's initial gearing selection is wrong, and that others are wrong too.
His point in this thread was a "?" Followed by irrational logic of needing poor gearing to drive home.
Which I can only deduce that he is a luddite.
Users browsing this forum: No registered users and 441 guests
