It is currently Fri Oct 09, 2026 9:10 am
Post Posted: Fri Sep 04, 2009 3:28 pm
I have a spare NT rear diff at home and i pulled the centre out of it to see what the ratio was. I counted 41 teeth on the crown wheel and 9 teeth on the pinion. Therefore the Ratio would be 4.56. Is this correct?? :?:
I didn't think that you could get 4.56 ratio's for the Suzuki?? :?:
86 LWB Sierra Ute
Toyota 5k with Toyota 5 speed
Post Posted: Fri Sep 04, 2009 3:32 pm
did ya check your counting?
Post Posted: Fri Sep 04, 2009 3:35 pm
i counted it twice cause i didn't think that it was correct.
86 LWB Sierra Ute
Post Posted: Fri Sep 04, 2009 4:04 pm
I'm pretty sure some model Vitaras came with that ratio.
Someone that has a bit more Vit knowledge will chime in hopefully.
Post Posted: Fri Sep 04, 2009 5:24 pm
1.3 or 1 litre size?
could be bits from a vit or an LJ80
Post Posted: Fri Sep 04, 2009 5:46 pm
I think that they are 1 litre. I got a complete set of diffs when i bought the ute and this is just one of the spare diffs that i have pulled apart to keep as spares.
They are either out of a ute or hardtop (both NT)
86 LWB Sierra Ute
Post Posted: Fri Sep 04, 2009 8:05 pm
wasnt that around the ratio that some vitaras had??the autos i believe??do you have a 1 ltr centre there to compare for size
matt
Post Posted: Mon Sep 07, 2009 12:33 am
If it's a 1 litre size, LJ80s came with 4.56 diffs. If it a 1.3 size, early Vits with an Auto box have 4.625 diffs.
If you're running 1 litre axle housings, your other options for R&P ratios are 4.875 from an LJ50 or 5.125 from a Super Carry.
Vehicle: Suzuki Vitara LWB
Post Posted: Mon Sep 07, 2009 7:49 pm
Its LJ80 ratio.
Post Posted: Mon Sep 07, 2009 7:53 pm
This is unusual that it is in a NT housing??
Does anyone want it?? it needs to be rebuilt as the bearings are all stuffed. I wil check the spare front and see if i have a matching pair for anyone interested.
86 LWB Sierra Ute
Post Posted: Tue Sep 08, 2009 10:17 am
Its a common way to lower gearing in a 1.0L diff. You can also use LJ50 which is 4.8.
Users browsing this forum: Google [Bot], shakes and 316 guests
