I have a 1997 Vitara with Calmini suspension installed. Since I have purchased this little truck, I have experienced a whine comi9ng from the rear end. It mainly occurs when I back of at hi speed and under load. With the attempt to use process of elimination I have changed the tail shaft, gearbox and transfer case, and the rear diff. I unfortunately still have this whine. My thought's are it maybe the angle of the rear uni due to the lift. Has anyone had the same problem and how did you solve it.
Users browsing this forum: Google [Bot] and 407 guests
