| Author |
Message |
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Fri Nov 14, 2014 6:13 pm |
Hey yal I'm looking to fit a sj80dash innmy turd (mg410) Can anyone tell me if I need to fit the sj80 loom? Or will it all plug up? Tin top coily to soft top mg410 if that makes any difference!
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
jonno_racing
 Posted: Sat Nov 15, 2014 10:37 pm |
Tonner
Joined: Thu Oct 23, 2014 2:14 pm Posts: 87 Location: Calamvale
Vehicle: Sierra
 Posted: Sun Nov 16, 2014 6:47 am |
Read somewhere where you need the wiring loom
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sun Nov 16, 2014 2:12 pm |
You will need the coily loom or at least the incab section. Or chop yours up and change all the plugs. Coily dash won't fit properly though.
IMHO it is too much work to get right.
jonno_racing
 Posted: Sun Nov 16, 2014 3:28 pm |
That's no real issue, why wont it fit properly? I was under the impression that I you swapped the crash bars and it worked?
want33s
 Posted: Sun Nov 16, 2014 6:31 pm |
The dash will fit but it won't line up with the bottom of the windscreen properly. Gaps etc. To the casual observer it'll look OK but anyone who looks closely will see only dodge.
jonno_racing
 Posted: Sun Nov 16, 2014 7:38 pm |
Ah ok.. I'm not massively fussed with bits like that  Do u use the sj80 heater box? Or can the mg410 work? Swapping looms is a better option as I'm considering going to the g13a and 5 speed as well
want33s
 Posted: Sun Nov 16, 2014 8:10 pm |
Firewall is different in coily so I'd be gathering all the bits together and then seeing what works.
jonno_racing
 Posted: Mon Nov 17, 2014 5:02 am |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13008 Location: Melbourne
 Posted: Thu Nov 20, 2014 11:21 am |
This conversion is going to bring the suck.
EVERYTHING is different. I've been in a WT LWB that had a coiler dash swapped in, and it was all sorts of a floppy loose mess.
Not worth it IMHO
