It is currently Thu Aug 13, 2026 11:27 pm
Vehicle: Samurai G16, DMax.
Post Posted: Thu Nov 13, 2014 5:04 pm
So its got three gear plus overdrive. Whats the go? Is that called a 3 speed or 4 speed? Back of my mind is transferring a G16B and 4 speed Vitara auto in.
Post Posted: Thu Nov 13, 2014 6:27 pm
I thought they were four speed. What makes you think it's three speed?
Post Posted: Thu Nov 13, 2014 6:29 pm
3 speed + OD :wink:
Post Posted: Thu Nov 13, 2014 6:48 pm
My auto is 5 speed but I have a clutch pedal and gear stick.
Post Posted: Thu Nov 13, 2014 6:56 pm
clutches, they just wear out & are sooo 2006. pompoms
Post Posted: Thu Nov 13, 2014 6:57 pm
Traitor ;)
Post Posted: Fri Nov 14, 2014 4:07 am
Its just the terminology I was trying to clear up. I know there are Vitara 3 speed autos which are basic and 4 speeds that are linked to the computer. Not having had much to do with autos I wonder if an auto nut would say I've got a 4 speed or 3 speed with OD. Can't sleep straight till I know:) I dont think Gus is an auto nut yet but I'm picking, it wont take much time.
Post Posted: Sat Nov 15, 2014 1:18 am
Four distinct speeds.
Three speed plus overdrive is 1960's terminology. By that reasoning, a five speed manual sierra is a four speed plus overdrive. In olden days many four speed manuals had an additional overdrive box fitted.
Post Posted: Sat Nov 15, 2014 4:12 pm
Thanks Steve. I learnt to drive in the 60s.
Post Posted: Wed Nov 19, 2014 6:11 am
The Vitara box is also a 3speed with overdrive, although its often referred to as an AW4 its actually an AW03-72LE
Vehicle: Which one?
Post Posted: Wed Nov 19, 2014 6:42 am
Not that 'olden days', even. The dodgy Jatco in VL commodores was a shitty 3-speed with an overdrive slapped on it.
Unless the late 80's are now considered olden days. They probably are :cry: .
Post Posted: Wed Nov 19, 2014 6:50 am
My folks had a import R31 Skyline that had a 3 speed with overdrive and just to confuse things further....a lock up on top of that.
Post Posted: Wed Nov 19, 2014 6:54 am
Sadly they are :shocked:
Post Posted: Wed Nov 19, 2014 12:59 pm
I don't think that's confusing at all. My X3 had eight speeds, two overdrive ratios (from memory) and lockup in every gear except first. I never had any idea what gear it was in.
Post Posted: Wed Nov 19, 2014 4:23 pm
Mustangs in the 80s came with a 4 speed box but it was referred to as a 3 speed + overdrive.
Back in the day overdrive was a big deal.
If your highest gear is overdriven (ie: less than 1:1) you have an overdrive box.
If your highest gear is 1:1 then you have a standard box.
Think about an Eaton Fuller 18 speed road ranger truck gearbox, 18 speeds and none are overdrive.
Users browsing this forum: Google [Bot] and 85 guests
