It is currently Mon Sep 21, 2026 7:25 pm
Post new topic Reply to topic  [ 155 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
Vehicle: suzuki jimny 2007
Post Posted: Sun Apr 26, 2015 4:09 am
pete_79 wrote:
sagi wrote:
Hi there...
A question about a combination i saw in the table...
is it possiable to fit Jimny VVT manual, with a pre-VVT M13A manual gearbox?
someone ever did that?
for example to take a 2003 manual transmission and put it on a manual VVT Jimny?
Yes it has been done.
There is tonnes and tonnes of great information in the rigs section.
You should start by reading this build and you will be sure to learn something from the master. :wink: http://www.auszookers.com/forum/viewtopic.php?p=307585#p307585
sorry but I haven't found anything specific about this swap.
maybe anyone knows what need to be done? and has pictures of one next to the other?
i want to make that swap to lower my revs...
Currently I run at 3600 in 90 KPH.
(235/75/15, Manual VVT with Auto VVT transfer with 4.7 Zeal gears in LOW, and 4.1 In both axles)
Vehicle: 91 Tin Top
Post Posted: Sun Apr 26, 2015 7:01 pm
sagi wrote:
pete_79 wrote:
sagi wrote:
Hi there...
Too hard to read through a few pages of great info???
Everything you've asked for is in the build thread I linked. Here's your photos, they are only 6 pages past the page I linked. http://www.auszookers.com/forum/viewtopic.php?p=388283#p388283
Post Posted: Mon Apr 27, 2015 9:18 pm
Double post.
Cheers Pete
Putting in a Sierra transfer will be worse plus your low range won't be as good as your Zeal low gears. Read my thread that Pete shared, it's all there.
A set of 31s will fix your problem. When you say 90 KPH is that speedo reading or Gps. 235s will cause a different reading to factory sized tyres.
Vehicle: Jimny JB33W G13BB
Post Posted: Sat Oct 03, 2015 2:22 pm
anybody knows a bolt on carrier that fits to a JB33W Differential carrier ive tried JB22W only the rear differential will fits but the front of JB33W differential carrier is small it does not fits the JA22W Front differential carrier any idea what suzuki unit bolt on to a JB33W differential carrier. A suplus dealer here is selling 5.37 ratio Bolt on carrier but its quite expensive any idea what type of Suzuki Unit differential carrier fits JB33W differential carrier 5.37 ratio. Thanks
Users browsing this forum: Google [Bot] and 217 guests
