It is currently Tue Sep 29, 2026 7:38 pm
Vehicle: MG410 WT
Post Posted: Mon May 18, 2015 8:51 am
Hi guys,
I have the F10a engine in my sierra, when i put the foot down on the accelerator when driving it will speed up and then will start to bog down for about 2 seconds then back to normal again.
Thinking it might be a carby issue, if anyone knows what the problem could be that would be great. Have done a full service on it recently.
Cheers,
Post Posted: Tue May 19, 2015 8:11 pm
Might be worth checking that the accelerator pump is working properly on the carby.
Vehicle: MG410 WT
Post Posted: Wed May 20, 2015 9:13 am
Q. Why does my Samurai hesitate when I accelerate?
A.
Quote from: Nissvit (nbs4x4)
The most likely problem is the accelerator pump or lack of it. If your zuke is hestitating (and all other obvious things have been checked) with the engine off, take the top of your carby and check that the accelerator pump squirts fuel in when you open the the butterfly... if you don't get a squirt of fuel in the primary throat you have found the problem...
Yeah thats what i had in mind, will try this ^^ and see what happens
Users browsing this forum: No registered users and 139 guests
