It is currently Fri Oct 02, 2026 4:38 am
Vehicle: 1997 2.0L JLX Vitara, 2 door.
Post Posted: Thu May 21, 2015 7:42 pm
For those of you who have put a 2" body lift in, is a steering shaft spacer needed? And if so where would I find one for my sv420 swb bit?
Post Posted: Thu May 21, 2015 7:44 pm
I've body lifted a few Vitaras and a heap of sierras. Never needed one.
Vehicle: Vitara 1994
Post Posted: Thu May 21, 2015 8:50 pm
Slightly OT but you don't seem like the type to body lift. Low and flat on big rubber seems more your theme.....
Post Posted: Thu May 21, 2015 11:26 pm
Body lift clears tyres and keeps all the weight of chassis alot lower than a susp lift. But bodys can walk on the mounts in extreme cases
Can u not just double up on the steering biscuit
Post Posted: Fri May 22, 2015 7:20 am
A BL is just a tool to fit bigger tyres. For example, it's quite difficult (but not impossible) to fit 35's on a low sierra without a body lift. For cars with tight guards that are difficult to cut, like a LWB Vitara, a BL can be very useful.
Mr Rocky's comments are spot on.
Post Posted: Fri May 22, 2015 9:27 am
Just extend the steering shaft?
Take it out, and tap it to lengthen it a little.
They are collapsible for crash purposes, there is enough length to safely extend it a tiny bit for a BL.
Post Posted: Fri May 22, 2015 4:34 pm
Cheers for the replies, hopefully all goes well without one.
Vehicle: SWB Vitara
Post Posted: Fri May 22, 2015 9:52 pm
I didn't really need one for 2" body lift, there was enough in the spline. I fitted some from bits4vits when we went to the 3" body lift.
Users browsing this forum: No registered users and 150 guests
