It is currently Sat Sep 26, 2026 5:00 am
Vehicle: Suzukiless these days..
Post Posted: Fri Sep 18, 2015 7:19 pm
Hi to the informed
And thanks in advance....
Just wonder , have swapped front struts over this after noon, camber is well out....
\ / <~ something like that in my best noobcad...
Question is I have to drive about 4-5 kms to get alignments done, will it be ok? If I drive real slow? Is there a chance anything could get damaged?
goddamitmyspacebarsbrokenagain
Vehicle: zook
Post Posted: Fri Sep 18, 2015 8:41 pm
You'll be fine. I drove 6 months after the lift with an eyeball alignment so I could convince the missus to get new tyres quicker.
Vehicle: SJ80, SE416
Post Posted: Fri Sep 18, 2015 8:53 pm
Look up instructions for setting up the camber bolts. Easily setup by eyeball in fact I have set mind to maximum negative camber in the past which still gave me a reading within spec just so I could remove and reinstall them later and still get the same adjustment. Most wheel aligners I have used are a bit lazy and will just set toe anyway unless you specifically ask them to adjust the camber bolts.
Post Posted: Fri Sep 18, 2015 9:32 pm
Thanks guys,
Its booked in tommorow at 9 for a wheel alignment,
Currently sitting in drive way with wheels pointing in crazy directions, I was half stressing about driving it to the tyre shop,. If it wont damage anything, I just drive it nice and slow.
Really not keen on playing with it at 730 in the morning.. just for 5 kms
Vehicle: Ford Maverick 4.2 Diesel
Post Posted: Fri Sep 18, 2015 10:51 pm
Just drive the thing noob
Post Posted: Sat Sep 19, 2015 6:48 am
:kissmyarse: Alex :kissmyarse:
Didn't your mum tuck you in last night
:thefinger:
Post Posted: Sat Sep 19, 2015 4:37 pm
Yeah....and I made it worth her while if you know what I mean uh huh mmmmmm
Users browsing this forum: No registered users and 28 guests
