It is currently Fri Nov 13, 2026 10:35 pm
Vehicle: sj80 coily
Post Posted: Tue Sep 29, 2015 11:39 am
Ok i want to fit a m18 and a auto to my jimny , firstly some info on my rig
I have a wt case 4:19 gearing spinal mount conversion , add engineering axels, arb lockers will the grabox be a bolt in swap and what difference are tge g13 and m series engine mounts .. wirings not a issue as im fiting a haltech
Vehicle: zook
Post Posted: Sun Oct 04, 2015 9:20 pm
The only auto that will bolt up to the m18 is the one from behind a m13. That particular auto will be your weakest link.
If your jimny is already a g13 then the g16B (coilpack = no wiring needed) will bolt up to a vit AW4 auto. Or even a j20a, if you want moar pow, with the AW4 will be bomb proof, possibly cheaper and less heartache in the long run.
G16 will use jimny or RB30 vl commie mounts + some fab (if you don't buy a mostly useless adapter kit). J20a will need some fabbed mounts.
M series will need ...oh wait.. theres a thread all about thishttp://www.auszookers.com/forum/viewtopic.php?f=17&t=30308
Users browsing this forum: Google [Bot] and 65 guests
