It is currently Fri Oct 02, 2026 4:50 pm
Post Posted: Fri Sep 18, 2009 11:05 pm
Hi All,
I have never had a soft top of any description before. Is it normal to have strong exhaust fumes?? Would a buggered catalitic converter give out strong exhaust fumes?? The timing and fuel mixtures etc are perfect. It had the probe thing up the pipe at the carby place.
Thanks
Rusho
Post Posted: Fri Sep 18, 2009 11:10 pm
hey mate, i just had to replace the cat on mine, didn't smell or anything just sounded like there was a loose rock in there lol rattled like buggery.
My Maruti build, Click WWW
how is your tail pipe setup, at rear of car?
Got a picture of how it is.
David
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Post Posted: Fri Sep 18, 2009 11:28 pm
I thought about gettin a bend downwards on it? What do you think?
Vehicle: 75 Cruiser
Post Posted: Fri Sep 18, 2009 11:33 pm
fumes in the cab means you're going too slow :thefinger:
heh.. nah.. fumes shouldn;t be that bad normally.
Post Posted: Fri Sep 18, 2009 11:37 pm
That's the reason why the fumes are getting sucked into back.
I know you will think it looks poxy but, the best position for the tail pipe is kicked out to the side. Like the way mister Suzuki has them factory.
There are other ways but it will get squashed when going up steep inclines, and that is to bring tail pipe out passed bumper bars by at least 2" or 50mm.
You could try get it angled down but I think it would only reduce it not eliminate it.
David
PS being a coily you could run the pipe out the pass side with out any issues, apart from how it looks.
My son had this issues with the pong and now his pipe is running out the side similar to std but a 2" pipe.
Zuki
Now just drive i
Post Posted: Sat Sep 19, 2009 12:23 am
I have the stock pipe, and get a few fumes sucked in.
My attempt will be:
replace crappy door seals
use velcro to stick the softop down, around all the clip on buttons
When I get motivated to do this, I will let you know how it works.
mainly to minimise the drafts in the car, my navigators always bitch about it being too cold and noisey.
it will also slow the ingress of water into the cab when in really deep stuff.
Post Posted: Sat Sep 19, 2009 12:51 am
My fumes were reduced when I had the new exhaust and cat fitted. I did end up sticking it out the side but a little different from original, not ideal but working for now.
Post Posted: Sat Sep 19, 2009 1:02 am
i have a fully adjustable zorst. 8) :lol:
Vehicle: MY2019 Jimny
Post Posted: Sat Sep 19, 2009 3:00 am
Looks like you have an orange gun mounted under there for tailgaters!
Yeah I just got mine plumbed out the side, it comes out as far as the bumper, and no more fumage.
Users browsing this forum: No registered users and 125 guests
