It is currently Wed Sep 23, 2026 4:01 am
Vehicle: 97 maruti ute
Post Posted: Mon Jul 11, 2016 9:04 pm
Hi guys, I've been trying to research doing a ruf on my wt mg410, but can only find info on nts?
If you could point me in the right direction?
Post Posted: Mon Jul 11, 2016 10:23 pm
It's pretty much the same except more work to support the mount offset from the chassis
Post Posted: Tue Jul 12, 2016 1:20 am
Okay sweet, so all the info about setting up nt rufs safely should be the same..
Post Posted: Tue Jul 12, 2016 12:24 pm
Your stock rear springs will bolt straight onto the front of your maruti with a longer shackle provided they are the stock spring.
You will however have to space your shocks back with some washers to prevent them hitting the bumpstop mount as well as longer beakelines and extended bumpstops depending on your shock length
Post Posted: Tue Jul 12, 2016 12:26 pm
You can see pics of it setup on my mg410 here - viewtopic.php?f=4&t=45997&start=60
Post Posted: Sun Jul 17, 2016 7:21 pm
How would you say that setup handles on the road rocky?
Handling is fairly important to me, since my rig will be about 50/50 on/offroad
Post Posted: Sun Jul 17, 2016 8:39 pm
100k kms on mine
Handle much better than full ruf, i slap swaybar in for onroad duties normally
Users browsing this forum: No registered users and 53 guests
