It is currently Sun Aug 09, 2026 12:34 am
Vehicle: D40 navara King cab
Post Posted: Fri Aug 19, 2016 9:10 am
Hi Team,
I picked up a LWB bare chassis for free, now i'm on the hunt for a ute cab.
It seems ALOT easier to track down a 1lt (no Booster) than a 1.3lt (Booster) cab. The car's basically going to be built for 4x4 only, and will have disks all round.
Therefor my question is, is it really that much better running a booster? or given the car will not be daily driven would it not matter to much.
Chris
Post Posted: Fri Aug 19, 2016 1:25 pm
Depends on the rest of the setup. I like my unboosted brakes but you need to very carefully choose booster size and with a low geared auto it can be tiresome due to pedal weight. If I was building again I'd build boosted.
Post Posted: Fri Aug 19, 2016 1:53 pm
Thanks Steve,
The plan is to run 33's all-round, WT diffs twin locked, reduction gears and 1.6lt motor w/ 1.3lt manual box.
Okay, it's quite difficult to mod a booster to fit a 1.0lt chassis correct?
Post Posted: Fri Aug 19, 2016 2:00 pm
Chassis is the same. It's the body that's the problem. Yes. The firewall is substantially different unless you find a type 3 ute cab.
Post Posted: Fri Aug 19, 2016 2:03 pm
Thanks, my apologies i meant Cab.
Looks like i'll need to wait until one pops up! (if they ever do haha)
Thanks Again Steve!
Post Posted: Fri Aug 19, 2016 3:07 pm
Running a remote booster is always an option.
Pretty common in rods and I've seen it a few times in drift/track cars. No clue how it would translate to a 4x4 but nothing jumps out at me.
A lot of effort and a few $$$ though.
Post Posted: Sat Aug 20, 2016 9:50 pm
I've seen 2 1ls with remote boosters. I've never felt the need for a booster in my unboosted Suzukis but they're near stock (so light) and running smaller tyres than most.
Post Posted: Mon Aug 22, 2016 6:37 am
Just cut down a swb soft top and put a Maruti back on it
Easy to find. Cheaper. More room
Post Posted: Mon Aug 22, 2016 11:49 am
Could you cut out a firewall from a wreck maybe?
Post Posted: Mon Aug 22, 2016 12:48 pm
Ive done a couple booster conversions on marutis.
Just swap the pedal box and enlarge the hole in the firewall, pretty simple.
Users browsing this forum: No registered users and 46 guests
