Hi all - new to this site and it looks very informative my problem is that the aircon has packed it in on my 2002 JLX Vitara (V6 7 seater) it has plenty of refrigerant and have checked fuses, relays etc. and was told by a guy that does auto electrics (not qualified but very good) that it may be the A/C controller that sits under the dash and gets plugged into the controller coupler and also the evaporator thermistor - so my question is would anyone be wrecking one of these or know where i could get one, - I live fairly remotely so cant just go to the wreckers appreciate any help The part number is 95510 - 64G00 and it is a denso - I have looked it up on Denso web and they say it does not exist - it is a small white box about 9 x 6 cm and 2cm deep - it has a circuit board in it and a 2 pin plug and also a long flat plug with 16 pins. alternatively can i use a different model one? I did take some photos but don't seem to be able to post cheers
Users browsing this forum: No registered users and 1 guest
