Joined: Sun Jan 29, 2017 8:36 am Posts: 75 Location: Kallangur North Brisbane
Vehicle: Suzuki Jimny 2010
Posted: Wed Apr 26, 2017 12:52 pm
Anyone got some junk they like to get rid off? And a few minor parts!
Drivers side front guard - damaged is ok, only after the plastic bit that goes at bottom for the mud flap attachment.
Rear diff housing - again damaged is ok. After the panhard rod attachment to use to make a template.
Coiley chassis - damaged - after the front panhard rod attachment horn, I want to cut this off with a bit of chassis to use to make a template.
Inner plastic wheel arch guards
Plastic trim covers for the rear trim - about 12*12cm - one on each side.
Ash tray
_________________ '10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Users browsing this forum: No registered users and 9 guests
