It is currently Thu Nov 05, 2026 5:07 pm
Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3
Vehicle: 1990 suzuki sierra
Post Posted: Fri Feb 28, 2014 8:36 pm
1DYX wrote:
Looking good!
Thanks mate :D
Ive still got a bit to do to it before its ready to be put on the vitara, but it should be worth it
Vehicle: stock
Post Posted: Sun Mar 09, 2014 6:38 pm
Have u seen these hard top they look very factory
vitara http://www.correlfiberglass.com/index.asp?PageID=32
Sierra http://www.correlfiberglass.com/index.asp?PageID=25
Vehicle: Suzuki Jimny 2003
Post Posted: Sun Mar 09, 2014 7:16 pm
lil_jim wrote:
Wow those hardtops look sweet :D :D :D
Post Posted: Mon Mar 10, 2014 5:24 pm
lil_jim wrote:
yeah they look good! i wonder if they would ship to australia ? probably end up costing more for shipping then what the canopy is worth :?
Post Posted: Sat Mar 15, 2014 4:29 pm
done a bit more work on the canopy today. trimmed it to size, made clamp points, and put the lid on.
ive still got a bit to do like:
marine carpet the inside of it
fiberglass over the plywodd clamp points to make them a bit stronger
fiberglass over the hinges so no one can try unscrew them from the outside
install the lock
repaint it
make a storage compartment for the jack, wheel wrench and other tools in the back
im also going to put a stainless bar set up on it similar to this one....
Vehicle: 1997 Sierra SJ80
Post Posted: Sat Mar 15, 2014 10:49 pm
Nice work, there.
Post Posted: Sun Mar 16, 2014 6:29 pm
Thanks. Im undecided on what colour im going to paint it. Im starting to think black to go with the bullbar, flares and rear bar.
Post Posted: Sun Mar 16, 2014 8:10 pm
A nice metallic gun metal grey. Compliment the lower body color of the vit.
Post Posted: Mon Mar 17, 2014 10:48 am
Nice! I like the look of that colour :)
Post Posted: Mon Mar 17, 2014 12:21 pm
I sent an email off to correl fiberglass that was shown on an earlier post and this is the reply that I got back from them
Hi Dear Peter,
We have mould renovation now. In a month we will sell plastic hardtops.
After a month i will send you a infromation about hardtop.
Best Regards
Koray Yamacı
The Engrish wasn't great but from what I can make of the reply they will be doing a plastic version pretty soon :-)
I will keep you updated as to what responses I get from them
Pete
Post Posted: Mon Mar 17, 2014 3:48 pm
Ok, will be interesting to see how much they cost :)
Post Posted: Mon Jun 16, 2014 5:47 pm
I finally got some time to finish my canopy off. Heres some pics...
Roof from inside. I marine carpeted it. Also going to add a led interior light to it
Front of roof from outside. Fitted and sealed nicely...
Inside the back. Have a bit of room for storage. Going to add some led lamps on pressure switches here for when im looking for stuff of a night..
Inside view of lock. Its a three point locking system. With a large "tongue" locking the lid in the centre and the two rods locking it on either side
Outside view of lock. Folding t handle style with key lock.
Inside view of the divider panel. Made from 20mm nida (we use it at work in igloo wall panels. It acts like insulation so will keep the heat in and sound out) with 2 layers of fiberglass over top and blue marine carpet. The hole is where my 8 inch sub will soon be.
Its 99% finished at this point but it is now mounted on the car and can stay on whilst driven :)
Things i still have to do:
Mount the subwoofer in the panel and make a sub enslosure
Make a sports bar style stainless bar to mount spotties/lightbar on.
Give it all a good buff and polish
Cheers! :D
Vehicle: Jeep
Post Posted: Mon Jun 16, 2014 10:07 pm
Nicely done, looks good, well done... :D
Post Posted: Tue Jun 17, 2014 7:06 am
Thanks mate :D
Post Posted: Tue Jun 17, 2014 7:02 pm
looks really good, but the rear window looks a little odd. in my opinion it needs to follow the shape of the roof line more.
Vehicle: 92 Suzuki Sierra
Post Posted: Wed Jun 18, 2014 12:45 am
i always thought a fiberglass roof styled like a 'tin top' with small windows etc would be awesome for a sierra soft top. After seeing you efforts Tassie i might have to give it a try!
Post Posted: Wed Jun 18, 2014 10:10 am
Thanks mate, i didnt even realise the shape of the window not following the roof. Could be something to change if i ever had to make another one.
Thanks. Takes a bit of work but i think its well worth it. I ended up spending $360 on materials which is alot cheaper than the $1100 or so for the rallytops from the states and i made it to suit my needs and i know it fits properly :wink:
Post Posted: Wed Jun 18, 2014 10:46 am
How much of that is just the resin/catalyst? Did you us conventional matting or something else?
Post Posted: Wed Jun 18, 2014 6:00 pm
I used approximately 15kg general purpose resin @ $5 a kilo
500ml of catalyst @ $10 a litre
For mat i used chop strand mat in 450gsm and 225gsm. (Gsm stands for grams per square metre)
Mat is approximately $7 kg from memory. I used about 20kg all together.
I also used some biaxial and triaxial mat which is just used for extra strength. Cant remember the exact price though. I used about 4 metres of that.
I buy my materials from work which means i get a staff discount though.
I spent more on clamps, rubber seals, led lights (yet to be installed), the steel for the sports bar which i will be installing soon, lock and the paint more than the actual fiberglassing materials.
Post Posted: Wed Jun 18, 2014 9:35 pm
$5 a kilo resin.. wish i knew where in sydney i could get that.
sounds crazy but most of the dd jobs of fiberglassing of late i use cotton rags and denim for the bulk. 10 layers is ridicolously strong, but i clamp it, not sure if that would work as for something like a hardtop.
Post Posted: Wed Jun 18, 2014 9:48 pm
The main problem i found was keeping the canopy light enough to easily lift off but strong enough so that it wouldnt flex to much. Mine is about 5 mm thick. Not sure of weight but i can easily handle it
Vehicle: 85 WT with SR20DE N/A
Post Posted: Mon Jul 07, 2014 12:50 am
If you start to make the roofs for the sierra I get one for sure
Vehicle: Suzuki sierra jx
Post Posted: Thu Oct 23, 2014 4:44 am
Count me for a roof for a sierra too
Post Posted: Wed Jun 28, 2017 1:50 pm
Grave dig..... Hows is this project coming along?
Have a need for a front section only, for a Sierra...
Users browsing this forum: No registered users and 15 guests
