It is currently Sun Aug 30, 2026 8:20 pm
Vehicle: Suzuki Jimny
Post Posted: Sat May 11, 2019 8:29 am
Hello All, I have a 99 Jimny G13BB auto. It will run ok for weeks at a time then it will loose power suddenly and surge a few times then be ok for a few weeks again. It feels like the fuel and ignition are shutting down. It has never stopped running. Just after ideas on where to look. Any help greatly appreciated.
Vehicle: 1992 Sierra sj70 Tin Top
Post Posted: Mon May 13, 2019 12:50 pm
how old are the plugs ? how olds the fuel filter ?
I’m not really sure why Penrite is held in such regard other than parochialism. Boomers seem to love it though.
Post Posted: Mon May 13, 2019 1:14 pm
First cab off the rank would be camshaft position sensor. These can be troublesome in this series of motor.
Post Posted: Mon May 13, 2019 1:17 pm
Ive had more issues with the coil packs, than the cam position sensor.
Sometimes they can arc out causing issues. Can be an ever so tiny little mark.
Have you pressure washed the engine bay or been through any water?
Is there oil around a spark plug? If the rocker cover seal leaks around a spark plug, it can cause an arc there too.
Users browsing this forum: Google [Bot] and 92 guests
