It is currently Thu Sep 03, 2026 2:58 am
Vehicle: lj50 soft top76
Post Posted: Tue May 19, 2020 10:15 pm
hi all if anyone has the part numbers for the lj50 crank parts and an exploded view pic i am extremely interested in tracking down new parts as i have come across a way to source them out off japan possibly with the part numbers. if not i will pic up the conversations on hopefully a good second hand one that could be rebuilt. i have all new bearings top and bottom and crank seals but would like also to replace the rods and rear pin crank section
more of these pages if someone has a parts manual would be great
Vehicle: 1978 LJ81
Post Posted: Wed May 20, 2020 9:14 am
Have access to LJ80 parts manual and it looks totally different.
Will see if i can get to an LJ50 manual for you.
Follow me on Instagram
www.instagram.com/project_marvin/
Facebook
Www.facebook.com/projectmarvinlj
Post Posted: Wed May 20, 2020 9:37 am
I have both the early and late LJ50 Parts Manuals, as well as the LJ80 and 80-II. Also have the JDM manuals for the SJ10 and SJ30 2 strokes.
The complete LJ50 main bearing sets have been unavailable for a few years. 2 of them are still available, but not all 4. I've checked for years through Japan, Singapore, Thailand and Dubai. All gone. As the dimensions of the bearings are standard sizes, it is possible for a machinist to modify standard bearings by machining, milling and drilling them to be suitable, but the hourly rate would leave you with $250 bearings.
The SJ30 crank was redesigned with forged and lightened components with bigger/wider bearings and so is good for 7000rpm. All parts/bearings/seals for the SJ30 style crank are still available new, and complete cranks are common 2nd hand from Japan. The SJ30 complete crank will drop straight into an older LJ50 crankcase. SJ30 bearings do not fit the older LJ50 crank.
Post Posted: Wed May 20, 2020 9:44 am
And that's not my only LJ Parts Manuals:
Post Posted: Wed May 20, 2020 10:17 am
Detail from the LJ50 and SJ30 engine pages, showing the lightened SJ30 crank components.
Vehicle: 1978 LJ81
Post Posted: Wed May 20, 2020 12:37 pm
had a look and, don't have them, seems 303zuke is all over it for you though :)
Facebook
Post Posted: Wed May 20, 2020 4:08 pm
Pics of an SJ30 crank.
Lighter, stronger components, balanced to 7000rpm. Bigger "Big End" bearings, wider Main bearings, but still fit early crankcases. Front snout is the late LJ50 style, so must be used with late timing pulley and fan spacer, but can also use a JA11 viscous fan.
All parts still avail thru Suzuki, or various resellers.
Post Posted: Mon May 25, 2020 10:28 pm
so the site went down and i have lost all messages from this point not sure if the same is for you but even our PM messages have disappeared? so where were we? 303zuke drop me AaPM
Post Posted: Mon May 25, 2020 11:16 pm
About what?
Post Posted: Tue May 26, 2020 4:24 pm
you have a pm
Post Posted: Fri May 29, 2020 6:48 pm
303zuke hey mate you have another pm thx
Post Posted: Sun Jun 07, 2020 1:57 pm
thx guys appreciate all your help, 303zuke parts are in the mail,
can anyone help out with lj50 conrod part numbers ?
Post Posted: Wed Jul 29, 2020 11:04 pm
LJ 50 part numbers
Main Bearings
No 22: 08113-60050
No 24: 09262-35001
No 33: 09262-30021 (x2)
No 34: 09269-35006
Con rod bearings
No 14: 09263-16008
No 29: 09263-23015
Crank seals
No 21: 09283-25054
No 25: 09289-44003
No 35: 12311-67010 (x2)
No 38: 09283-35006
 Profile YIM
Post Posted: Sun Aug 02, 2020 10:38 am
thx mate, all sorted now ended up finding a complete new old stock crank out of Indonesia bolted straight in and running mint:)
Post Posted: Sat Aug 15, 2020 11:21 pm
What did that cost you?
 Profile YIM
Post Posted: Tue Aug 18, 2020 6:33 pm
I bought 3 new conrods as well to do up my original crank as I have a complete set of seals and bearings to fully rebuild it I might sell those parts off, the new crank set me back around $700 it has bigger conrod big end bearings than the original freight and GST was up there though I think total cost was $1350 including the new rods and it only took 8 days from Indonesia to my door
Users browsing this forum: No registered users and 10 guests
