It is currently Tue Sep 22, 2026 2:23 pm
Vehicle: Toyota FJ40 Landcrsuier
Post Posted: Mon Apr 25, 2022 7:39 am
G'day everyone,
I just picked up a 1983 SJ40V and had a few questions. Body is in fantastic condition and I play on giving it a respray. I understand it is the 1.0L engine and I was just after some thoughts on whether to keep it stock or do an engine conversion? I was thinking maybe a F6A Turbo. Or just keep her original? The 1.0l seems a little lacking in power and I have heard the gearbox isn't fantastic off road.
Cheers,
Sam
Vehicle: 98 coily..Max.
Post Posted: Fri Apr 29, 2022 6:39 pm
Congrats bro,
you should do engine conversion and gift me the 1l transfer case as reward
for great advice Armsup
Welcome brother.
p.s.ignore me,i got a coily Armsup
Suzuki...four wheel jive!
98 coily...Camping rig.
Post Posted: Fri Apr 29, 2022 6:49 pm
If you can find and F6A in good condition it’s a great conversion.
Vehicle: Suzuki LJ Ute
Post Posted: Sun May 08, 2022 9:30 am
Where could you get a F6A from though? Maybe in a wrecked suzuki carry or Cappuccino? Would be hard to get imported too
Post Posted: Sun May 08, 2022 9:49 am
The cappuccino engine is peak F6A being DOHC, and RWD trim, but the gearbox is unsuitable as it has a remote shifter like a Jimny gearbox that puts the shifter over the top of the transfer case. I suspect a Carry would have a similar problem in reverse. (i'e the shift housing is cable or whacky linkages to get it forward)
There are quite a few F5A and F6A sierras in the country though. I suspect motors (and more importantly, gearboxes) do turn up.
I don't know the status of importing 1/2 cuts any more, but that's the obvious way to get everything required - A K6A Coil sprung front cut would be ideal. It would also supply electric power steer and A/C.
There used to be a market for Alto Works F6A front cuts which are basically the cappuccino engine in FWD trim - The mighty boy bois used to be all over them. I haven't looked for many years.
Users browsing this forum: Google [Bot] and 130 guests
