It is currently Wed Mar 27, 2019 5:40 am
Vehicle: Suzuki Sierra SJ80
Post Posted: Wed Jul 04, 2018 12:34 pm
Hi, I’ve noticed the hose from the brake booster to the manifold is a bit ratty and wanting to replace, does this hose have a check valve inside it and what sort of hose should I use
? (Car is sj80 1.3l)
Thanks
Post Posted: Wed Jul 04, 2018 2:23 pm
Usually the check valve is on the booster rather than in the vacuum lines, I believe that there are a few in-line check valves but not commonly.
Vehicle: SJ80, SE416
Post Posted: Thu Jul 05, 2018 7:21 pm
They aren't in the booster on an SJ80 as I remember vacuum being present when pulling the hose off the booster. I can't remember if the valve is in the hose though like on a Vitara.
Vehicle: SJ51WT.FZJ105R.XKWags
Post Posted: Fri Jul 06, 2018 1:10 pm
No check valve inside the hose. Hose doesn't have to be anything special. Just choose something black
Post Posted: Fri Jul 06, 2018 1:30 pm
*that doesn’t collapse under vacuum. Easily overlooked.
hillbilly 2 wrote:
Gwagensteve is why auszookers will never be taken seriously
Users browsing this forum: No registered users and 6 guests
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC + 10 hours
