It is currently Sun Jan 26, 2020 11:03 pm
Vehicle: 96 LWB Vitara 1.6L
Post Posted: Sat Jan 11, 2020 10:49 pm
Hey guys .. should be an easy one but im gonna ask anyways . I have myself a 96 LWB Vit and just threw in an aftermarket central locking system.
Now the locking and unlocking went in easy no dramas but I'm trying to just splice in the remote wires to make the indicators flash when I lock and unlock .. is there any easy way to do this ?
Because I can't seem to find the correct wires to splice to under the dash ??
If anyone has some photos of how they did it that would be awesome! [emoji1365]
Sent from my CPH1877 using Tapatalk
Vehicle: 98 5 dr SQ420, 05 5dr JB420
Post Posted: Sun Jan 12, 2020 6:12 am
Are you serious?
Assuming the aftermarket system is equipped to flash the indicators rather than the side lights, all you need to do is locate the harness coming out of the column switch and tap into it, preferably on the dash harness side of the connector, another location that might be easier is the dash cluster connector.
You're looking for green/red & green/yellow cables.
If the aftermarket system only has one output lead for the indicator you'll need to add either blocking diodes or a dual pole relay to maintain isolation between left & right side indicators.
Users browsing this forum: Google [Bot], Gwagensteve and 3 guests
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC + 10 hours
