| Author |
Message |
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Aug 01, 2009 1:35 am |
I've been trying to work out what sort if gearing to roll with in my zook so this is the info i found and collected i figured i may aswell share it. If anyone else know of other ring and pin for Vitaras that will fit sierra housings then tell me and ill put it in
Sierra, High: 1.409, Low: 2.268
Sierra ring and pin: 3.9, 3.7, 4.1
Superior Engineering, ring and pin: 4.57, 5.38
Snake Racing: Series One, High: 12%/1.691, Low: 4.16
Snake Racing: Series Two, High: 18%/2.536, Low: 5.14
Snake Racing: Series Three, High: 20%/2.818, Low: 6.5
Superior Engineering: High: 16%/2.254, Low: 4.9
Vitara, High: 1.00, Low: 1.907
Vitara ring and pin: 5.12
X-90 4.875
BBM, High:N/A, low: 110%/2.187
Snake Racing, high: N/A: 120%/2.206
http://www.izook.com/gearcalc.htm
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Sat Aug 01, 2009 1:45 am |
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Sat Aug 01, 2009 12:59 pm |
Zook_Fan wrote: X-90 are 4.875
rlly?
_________________ SJ50.4.LYF
CairnsZook
Joined: Tue Jul 18, 2006 11:30 pm Posts: 872 Location: West Coast
Vehicle: Zookless
 Posted: Sat Aug 01, 2009 1:25 pm |
I don't think all X-90s are 4.875, but I have some R&Ps at home that are.
303zuke
Vehicle: LJ50V, SJ70
 Posted: Thu Aug 20, 2009 9:39 pm |
And SE416 Vits with 3 speed Auto are 4.625:1
31zook
 Posted: Sun Sep 13, 2009 8:18 pm |
303zuke
 Posted: Mon Sep 14, 2009 2:29 am |
31zook wrote: I've been trying to work out what sort if gearing to roll with in my zook so this is the info i found and collected i figured i may aswell share it. Sierra, High: 1.409, Low: 2.268 Snake Racing: Series One, High: 12%/1.691, Low: 4.16
The ratios you've shown for the stock Sierra are for the 1.3lt transfer gears.
The 1.0lt cases are:
High:1.590, Low: 2.558
The 4.16 gear sets are a hybrid of the 1.0 and 1.3 gears and the High is the stock 1.0 ratio of 1.590 and the Low is 4.16.
303zuke
 Posted: Mon Sep 14, 2009 2:33 am |
31zook wrote: Vitara, High: 1.00, Low: 1.907
BBM, High:1.00, low: 110%/2.187 Snake Racing, high: 1.00, Low 120%/2.206
Are those ratios correct, as they don't appear to be 110% or 120% lower than stock?
Calmini and Lowrange Offroad have Vitara 4.24 t/case gears which are 134% lower than the 1.907 stock.
31zook
 Posted: Thu Oct 08, 2009 10:14 pm |
cheers
31zook
 Posted: Sun Apr 11, 2010 2:23 pm |
303zuke
 Posted: Wed Oct 13, 2010 11:16 am |
303zuke wrote: 31zook wrote: Sierra, High: 1.409, Low: 2.268
Snake Racing/Rockhopper etc: Series One, High: 12%/1.691, Low: 4.16
The ratios you've shown for the stock Sierra are for the 1.3lt transfer gears. The 1.0lt cases are: High:1.590, Low: 2.558 The 4.16 gear sets are a hybrid of the 1.0 and 1.3 gears and the High is the stock 1.0 ratio of 1.590 and the Low is 4.16.
I made this up and it may be of some help to someone (numbers on the gears are number of teeth).
Each of the 4.16, 4.9 and 5.14 gear sets keep the original 1.3lt low range output gear and only replace the others. This may be good to know if you start off with a 1.0lt case as you won't have the full set of gears to make up the new ratios.
The 4.16 gears use the input and high output gear from a 1.0lt case, so if you have a 1.0lt case, you will need to find a 1.3 Low output gear.
The 6.5 gears replace all gears in the case with new items, you don't need any gears from your original gearset.
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Sun Jan 02, 2011 3:21 am |
This may be a real stupid question but can stock WT transfer retain it's stock 1:409 High Range but have a lower than stock Low Range installed?
_________________ Click WWW below for STICKERS
BlueSuzy
 Posted: Sun Jan 02, 2011 3:36 am |
Maybe, But all gearsets come out with both reduced.
31zook
 Posted: Sun Jan 02, 2011 3:56 am |
zukenutter wrote: This may be a real stupid question but can stock WT transfer retain it's stock 1:409 High Range but have a lower than stock Low Range installed?
a vit tcase can
Percy
Joined: Mon Nov 30, 2009 10:30 pm Posts: 58 Location: Brisbane
 Posted: Sun Jan 02, 2011 4:55 am |
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Tue Jan 11, 2011 6:12 am |
Percy wrote: I use this gear calculator, allows you to compare as well as input tire size and gives you crawl speed, speed at given rpm and rpm at given speed. http://www.grimmjeeper.com/metric_gears.html
X2
I was using the imperial one for a few weeks until I realised the metric one was working.
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Tue Jan 11, 2011 6:19 am |
Damo wrote: Zook_Fan wrote: X-90 are 4.875 rlly?
Auto X-90 is 4.6. I have 2 of them in my ute.
_________________ 2013 GV 1998 SV420 ute
bazook
Joined: Sat Jul 12, 2008 11:30 pm Posts: 1082 Location: brisbane logan
 Posted: Sat Jan 22, 2011 7:51 pm |
heres a site that tells you the size of tires and the actual size of them plus some calculators to help out with gear ratio and stuff
LINK
_________________ josh AKA Bazook
Highway-Star
Joined: Thu Apr 30, 2009 11:30 pm Posts: 4109 Location: Ipswich
 Posted: Sat Jan 22, 2011 9:24 pm |
The closest to feasible way I can see you doing this, is to make a cut and shut 'lobster' using a standard 1.3 case, and a set of 6.5's. Use the input and high range gears sets from the standard case, and the 2 low range gears from some 6.5's. You'll end up with the standard 1.409 high range, and a slightly lower 2.7:1 low range.
I theory you could cut and shut any pairs of these gears to give a few other gearing options...
_________________ Clearance Hole Technology
zukenutter
 Posted: Sun Jan 23, 2011 4:49 am |
after a day of swapping transfers I've just come to the realisation that I'm screwed. My plan was to swap my old 2001 Jimny transfer (with 24% reduction gears into my new VVT Jimny. Only problem while installing it was that the Jack shaft was too short, it still went on but obviously with less overlapping spline. I had a 2001 Jack shaft under the house which was the correct length but the spline although appearing the same wouldn't slide on to the gearbox output. I test drove it with the shorter shaft only to realise that the standard VVT transfer is much taller geared... end result was a top speed of about 90km/h in 5th and doing 5000rpm, not my desired outcome.
Got home and checked the VVT transfer high range ratio and it was 1.0 as opposed to 1.3.
So now I know I could fit a standard early M series transfer for a 30% reduction but that's too much. Sierra case is now way past what I want as well. Is their a Suzuki transfer with a high range ratio of 1.1 or similar?
zukenutter
 Posted: Wed Mar 02, 2011 11:07 am |
Highway-Star wrote: zukenutter wrote: This may be a real stupid question but can stock WT transfer retain it's stock 1:409 High Range but have a lower than stock Low Range installed? The closest to feasible way I can see you doing this, is to make a cut and shut 'lobster' using a standard 1.3 case, and a set of 6.5's. Use the input and high range gears sets from the standard case, and the 2 low range gears from some 6.5's. You'll end up with the standard 1.409 high range, and a slightly lower 2.7:1 low range.
This sounds perfect. Could it be done using low range gears from a one litre.
Highway-Star
 Posted: Wed Mar 02, 2011 9:42 pm |
zukenutter wrote: Highway-Star wrote: zukenutter wrote: This may be a real stupid question but can stock WT transfer retain it's stock 1:409 High Range but have a lower than stock Low Range installed? The closest to feasible way I can see you doing this, is to make a cut and shut 'lobster' using a standard 1.3 case, and a set of 6.5's. Use the input and high range gears sets from the standard case, and the 2 low range gears from some 6.5's. You'll end up with the standard 1.409 high range, and a slightly lower 2.7:1 low range. This sounds perfect. Could it be done using low range gears from a one litre.
Sort of yes, but it would be silly.
You'd end up with a low range that is higher than the factory 1.3 case gives.
The only one worth doing would be using the low range gears from the 6.5's. All the other after market gearsets use the low range gears from a standard 1.3 case.
zukenutter
 Posted: Thu Mar 03, 2011 12:40 am |
Highway-Star wrote: zukenutter wrote: Highway-Star wrote: zukenutter wrote: This may be a real stupid question but can stock WT transfer retain it's stock 1:409 High Range but have a lower than stock Low Range installed? The closest to feasible way I can see you doing this, is to make a cut and shut 'lobster' using a standard 1.3 case, and a set of 6.5's. Use the input and high range gears sets from the standard case, and the 2 low range gears from some 6.5's. You'll end up with the standard 1.409 high range, and a slightly lower 2.7:1 low range. This sounds perfect. Could it be done using low range gears from a one litre. Sort of yes, but it would be silly. You'd end up with a low range that is higher than the factory 1.3 case gives. The only one worth doing would be using the low range gears from the 6.5's. All the other after market gearsets use the low range gears from a standard 1.3 case.
Now I'm confused.
Jimny NON VVT, High 1.32, Low 2.145
Sierra 1.3, High: 1.409, Low: 2.268
Sierra 1.0, High: 1.590, Low: 2.558
I want, High: 1.409, Low: 2.558
Highway-Star
 Posted: Thu Mar 03, 2011 1:22 am |
zukenutter wrote: Highway-Star wrote: zukenutter wrote: Highway-Star wrote: zukenutter wrote: This may be a real stupid question but can stock WT transfer retain it's stock 1:409 High Range but have a lower than stock Low Range installed? The closest to feasible way I can see you doing this, is to make a cut and shut 'lobster' using a standard 1.3 case, and a set of 6.5's. Use the input and high range gears sets from the standard case, and the 2 low range gears from some 6.5's. You'll end up with the standard 1.409 high range, and a slightly lower 2.7:1 low range. This sounds perfect. Could it be done using low range gears from a one litre. Sort of yes, but it would be silly. You'd end up with a low range that is higher than the factory 1.3 case gives. The only one worth doing would be using the low range gears from the 6.5's. All the other after market gearsets use the low range gears from a standard 1.3 case. Now I'm confused. Jimny NON VVT, High 1.32, Low 2.145 Sierra 1.3, High: 1.409, Low: 2.268 Sierra 1.0, High: 1.590, Low: 2.558 I want, High: 1.409, Low: 2.558
The way Sierra transfers work, is low range is dependent on the high range gearing. You change high, low changes with it. You can change low without effecting high, but there are only 3 different pairs of low range gears:
The 1L pair: 47/32 ~ 1.47 (only used in standard 1L light cases)
The 1.3 pair: 56/23 ~ 2.43 (used in 1.3 cases, 4.16, 4.9 and 5.12)
the 6.5 pair: 67/23 ~ 2.91 (only used in 6.5 gears)
These are not your overall low rage ratios, these values have to be multiplied by the input pair of gears. The input gears are different on every single Sierra case variant. The only one thats used twice is the 1L pair, which are used in the 4.16 rocklobster. All input gears are a reduction pair, except the 1.3 case, which is actually an overdrive! This is why replacing the 1.3 high range gears with 1L high range gears gives the significant change in low, as the low range pair is now multiplied by a reduction pair of gears.
As for wanting "I want, High: 1.409, Low: 2.558", you cannot do it. The closest is all the 1.3 high range gears, and the 6.5 low range pair. This gives you 1.409, 2.7.
Just for completeness sake, take the 1.409 high range set, and mix it with all 3 low range pairs listed above:
The 1L pair: 1.409, 1.37
The 1.3 pair: 1.409, 2.27
the 6.5 pair: 1.409, 2.71
Pretty bad when the low range ends up higher than high range!
BTW, basically all the info you need is in that diagram 303zuke posted above.
Highway-Star
 Posted: Thu Mar 03, 2011 1:41 am |
OK, I've photochopped 303zukes diagram so you can see how its calculated.
Use the teeth count instead of numbers 1, 2, 3, 4, 5.
When mixing and matching gears; 1,2,3 have to remain as a matched set, and 4,5 have to remain a matched pair. When physically making them, gears 2 and 4 are joined together on one "shaft", and thats the shaft that gets cut and welded in a rocklobster.
zukenutter
 Posted: Thu Mar 03, 2011 1:57 am |
Cheers Aaron, I should have referred back to that diagram as it does explain things well. I wasn't keeping the input gear in mind. BTW i really like your avatar.
smiffkid
Joined: Fri Aug 13, 2010 12:55 pm Posts: 3266 Location: perth wa
 Posted: Mon Apr 04, 2011 12:47 pm |
is there any diff gears out there that will fit a jimny
_________________ dodgy brothers mechanical
Highway-Star
 Posted: Mon Apr 04, 2011 2:02 pm |
smiffkid wrote: is there any diff gears out there that will fit a jimny
Jimny ones...
Japanese domestic market should have 5.375:1 diffs from K6a auto Jimnys that might fit, if its low you are after...
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
 Posted: Thu Sep 15, 2011 7:44 am |
Just trying to work out some gearing here. See if i worked it out correct.
1.6 EFI, 3 speed auto, stock sierra trans, 3.7's
27" 4055RPM at 100kph
28" 3910RPM at 100kph..
1.6 EFI, 3 speed auto, stock vit transfer, 3.7's
27" 2878RPM at 100kph
28" 2775RPM at 100kph
Can anyone see an issue with 2900RPM at 100, or is that going to be too low?
I want to stick with a 3 speed due to size. So i've only got transfer or diff gears to play with. Id prefer not touch diffs though.
Highway-Star
 Posted: Thu Sep 15, 2011 8:05 am |
boostedbrick wrote: Just trying to work out some gearing here. See if i worked it out correct.
1.6 EFI, 3 speed auto, stock sierra trans, 3.7's 27" 4055RPM at 100kph 28" 3910RPM at 100kph..
1.6 EFI, 3 speed auto, stock vit transfer, 3.7's 27" 2878RPM at 100kph 28" 2775RPM at 100kph
Too little RPM for a zook to be happy. Plus the low range would be horrid, and the Vitara transfer will not even close to be a good idea to use in a Sierra.
the 3900rpm might be OK. If you really wanted to get some slightly higher road gearing into it, put a coily transfer in (will need front tailshaft and maybe jackshaft? to go with it). I think your low would suck then though....
