It is currently Mon Jun 08, 2026 2:19 pm
Post Posted: Tue Feb 05, 2013 8:03 pm
I have heard rumours that the front diff is soft on the Auto GV's
How can I tell what the hell mine is ??
Its a 2001 5 speed Manual if thats any help ?
Post Posted: Tue Feb 05, 2013 8:10 pm
pretty sure the XL-7's use a different diff than the GV's/Vitara's so you wont be able to bolt in a steel diff, but i believe they're a cast steel diff anyway.
for what you want to do it will be fine.
Vehicle: JB420, APK416, A6G415, A6N415
Post Posted: Wed Feb 06, 2013 9:16 am
As far as I know a 2001 XL-7 runs the same front diff as a GV - final drive ratio will be different, but the housings are the same - if you want to know if it's steel, get a magnet. The rear diffs are different.
Vehicle: 2002 Suzuki XL7
Post Posted: Wed Feb 06, 2013 12:58 pm
I thought they where steel, i guess a magnet to the diff will tell you or the sound of a screw driver against it.
Bellow say there aluminum.
Suzuki XL-7 4dr Automatic 4WD
Engine
Type: V6 Gasoline
Displacement: 2.7L / 167 CID
Fuel System: MPFI
SAE Net Horsepower: 183 @ 6000 RPM
SAE Net Torque: 180 @ 4000 RPM
Transmission
Type: 4-Speed Automatic w/OD
First Gear Ratio: 2.83
Second Gear Ratio: 1.49
Third Gear Ratio: 1.00
Fourth Gear Ratio: 0.69
Reverse Ratio: 2.70
Transfer Case
Gear Ratio (high): 1.00
Gear Ratio (low): 1.82
Axle(s)
Front: Independent McPherson Strut (w/coil spring)
Axle Housing: Aluminum
Rear: 5-Link (w/coil spring)
Axle Housing: Steel
Final Drive Ratio: 5.13
__________________
Post Posted: Wed Feb 06, 2013 1:22 pm
Magnet sticks to it..
I just used a weak fridge magnet and she stuck solid....
Post Posted: Wed Feb 06, 2013 1:40 pm
Guess its steel then.
There are lots of confusion about this on other forrum's, i always thought it was steel and quite hard steel, while the early GV's had the alloy diffs.
I cant see why suzuki will put a alloy diff on just because its a auto and not a manual, the whole drive train was made stronger to handle the extra weight and torque etc.
The transfer case on the other hand i have read in the suzuki manual is a aloy case, its tuck well up there and above a cross member so never has been hit, but always thought about putting a bash plate there.
Post Posted: Wed Feb 06, 2013 2:12 pm
The Rear is also steel.. Magnet doesn't stick to the transfer...
Post Posted: Wed Feb 06, 2013 7:52 pm
If you look at around 21:38 of the video i posted earlier, you can see a rock i hit, it bent up the bash plate around the front diff and hit where the diff plug is, not one scratch on the diff. if that happened to a alloy diff it would of cracked in half like a coconut, or at least lost all the oil in it..
Bash plates do a good job at protecting the sump but would be better if they where steel not alloy
Post Posted: Thu Feb 07, 2013 4:58 am
Yeah I looked on mine, there is no bash plate, just a cross member So its something I will have to rectify..
The fuel tank has a bash plate but the other components just have a cross member underneath them as protection..
Users browsing this forum: No registered users and 9 guests
