It is currently Sun Jun 07, 2026 4:18 pm
Vehicle: 98 Jimny
Post Posted: Sun Nov 23, 2014 1:10 pm
Hi everyone, has anyone replaced a steering box in a non power steering jimny?
Also how do you take the rear bump stops off? does it have a thread??
Thanks Michael
Post Posted: Sun Nov 23, 2014 4:57 pm
Yes....
What exactly are you trying to ask?
Vehicle: 98 Jimny
Post Posted: Mon Nov 24, 2014 12:40 am
is it hard to replace it? what do you have to do to replace it?
Post Posted: Mon Nov 24, 2014 4:57 am
I can't speak specifically for access considerations in relation to the Jimny, but there's three bolts holding the box to the rail, one bolt to remove to free the steering shaft from the input side of the box, and you'll need a pitman arm puller or tie rod end splitter to remove the pitman arm or drag link, depending on what the new box comes with.
It's not a technically difficult job, and other than the puller/splitter it doesn't require any special tools. As per normal though, access is what makes or breaks the job.
Vehicle: 98 Jimny
Post Posted: Mon Nov 24, 2014 5:07 am
Thanks heaps Steve for the advise
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Nov 24, 2014 12:05 pm
i cant confirm, bu always thought the jimny nonPS box and PS box were the same, just where the hoses went on were blanked off with bolts. they even run the same PS fluid to fill them.
youll need the pump, belt and hoses if its the case
Post Posted: Mon Nov 24, 2014 12:29 pm
Didn't get the impression the OP was asking how to convert? Could be wrong though. I'm sure the box is externally very similar.
Vehicle: 98 Jimny
Post Posted: Thu Nov 27, 2014 10:09 am
im not sure how much work would it be to convert it to power steering??
Post Posted: Thu Nov 27, 2014 10:18 am
Different box, you'd need power steering pump, reservoir, and lines. Depending on how long the non power steering box is you might need to modify the steering shaft by shortening it like you do for a sierra.
