It is currently Sun Jun 07, 2026 4:19 pm
Vehicle: Tin Top
Post Posted: Sun Dec 21, 2014 5:52 pm
If possible,can I buy spring perches?
Make or buy, what do people do/use?
Am putting WT diffs under my NT n chasing 4
Post Posted: Sun Dec 21, 2014 7:45 pm
I bought a set from tsor (not operating any more)
I didn't bother getting them again, the simple ones were fine, the one I didn't want to make myself was miles out of fitting properly, and took a lot of fiddling to get sitting nice.
Careful cutting you can reuse your old perches.
Or a set of verniers and set of holesaws and grinder and you can make your own
Post Posted: Sun Dec 21, 2014 8:33 pm
I just did this job and was in the same place. I only did the rear so I've only half the story.
I got some 50x100 rhs that was lying around and used a hole saw. The rear is 65mm which requires you to drill it off centre by approx. 11mm centre to centre.
then cut in to two pieces. Then I put the two pieces in the vice to make sure that the spring centring dowel is level. its a 14mm if I can remember.
Hope that helps.
Post Posted: Sun Dec 21, 2014 11:04 pm
^^this is how mine are made.
Be careful when you cut though - if you're SPUA and you leave a bit too much meat on you'll essentially be adding lowering blocks =)
