| Author |
Message |
matth27
Vehicle: Sierra
 Posted: Tue Sep 03, 2013 8:03 pm |
Trying to remove my rear drums and one of the splines is stripped and the stud just keeps spinning. Any ideas on how to undo it?
pezz
Joined: Fri May 15, 2009 11:30 pm Posts: 2108 Location: western vic
Vehicle: sj51
 Posted: Tue Sep 03, 2013 8:07 pm |
cold chisel is one option
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Tue Sep 03, 2013 8:29 pm |
Hit with a hammer to remove the stud, and replace it
pezz
Vehicle: sj51
 Posted: Tue Sep 03, 2013 8:31 pm |
think he means the nut is still on the stud
jono165
Joined: Thu May 27, 2010 12:01 pm Posts: 834 Location: Melbourne
 Posted: Tue Sep 03, 2013 8:42 pm |
I'd just cut the nut off and replace the stud. If the hole in the axles is stuffed from the stud spinning i'd just source a 2nd hand axle.
buzbox
 Posted: Wed Sep 04, 2013 6:59 am |
Well that's a bit more of a complex operation then. Angle grinder to chop it off.... Then hammer
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Wed Sep 04, 2013 7:15 pm |
More complex that what?
bye
atari4x4
Joined: Mon Dec 11, 2006 10:30 pm Posts: 34843 Location: East Radelayed
 Posted: Wed Sep 04, 2013 7:24 pm |
Hi  what bit don't you get? pretty sure he means it's not as simple as knocking out the old stud as mentioned in an earlier post of his & if the nut is still on & it's spinning the knurled section on the stud or the wheel nut is stripped it will need to be cut off. Bye
buzbox
 Posted: Thu Sep 05, 2013 12:54 am |
An explanation of an explanation, now that's deep. Thanks Atari , your like a miniature Buddha
