It is currently Thu Sep 24, 2026 6:47 pm
Vehicle: 98 Coily
Post Posted: Fri Oct 25, 2013 5:50 pm
This doesn't seem stock but I am wondering if it'll do as a proper recovery point? picture was taken from directly underneath looking up. There is a similar point up front but rather than bolted it was welded on. both points were from the previous owner. any comments appreciated.
Post Posted: Fri Oct 25, 2013 8:43 pm
That's stock for a coil car. Contrary to what the naysayers reckon, you won't die, nor will the sun implode to a black hole if you use it for recovery. Just be sensible and don't get snatched out by a Neanderthal in a patrol on the limiter in 2nd low.
Vehicle: 98 Coily
Post Posted: Fri Oct 25, 2013 11:17 pm
Cheers Steve
Post Posted: Sat Oct 26, 2013 7:50 am
Yes but often people who pull you out often have no clue how to do a proper snatch..
Check to see if you can identify if the bolts are High Tensile or if they are some kind of cheap bunnings job...
Vehicle: 98 Coily
Post Posted: Sat Oct 26, 2013 8:57 am
Will do.
