It is currently Thu Sep 24, 2026 7:45 pm
Vehicle: Soon to be Sierra (hopefully)
Post Posted: Mon Oct 28, 2013 10:48 am
How hard is it to put p/steer and a/c into a sierra?
How hard is it to put a J20A in , does it require a stronger transfer case. donor would be a 1.3L sierra
Also someone on the facebook page said there was a LWB soft top as the discussion was about a hard canopy for a LWB. Whats the differences between them :)
also is a WT better? can you get hard canopies for them as well ?
Had no luck finding a nice 2L vitara lately so im resorting back to the tin box sierra :D
Post Posted: Mon Oct 28, 2013 12:03 pm
frysie wrote:
How hard is it to put p/steer and a/c into a sierra? Jimny stuff bolts in. You can use a Vitara steering box with an adapter
How hard is it to put a J20A in , does it require a stronger transfer case. donor would be a 1.3L sierra Quite hard. You'l need to chop the trans tunnel out, make new engine mounts and all sorts of things like that. The Sierra transfer should live depending on your driving style. Why do you want a J20a? A G16b is a much easier and much more well trodden path.
Also someone on the facebook page said there was a LWB soft top as the discussion was about a hard canopy for a LWB. Whats the differences between them :) Basiically, the wheelbase. There's no real differences between LWB and SWB aside from the length.
also is a WT better? can you get hard canopies for them as well ? Depends what you want to do with it. Buy a NT if you want to do heaps of hardcore offroading so you can utilize the narrower spring spacing and fit WT diffs. Otherwise, buy a WT. Do not buy a coily if you want to mod stuff. Yes you can get canopies for them, they're a little rare these days though.
Post Posted: Mon Oct 28, 2013 12:15 pm
sideways wrote:
frysie wrote:
How hard is it to put p/steer and a/c into a sierra? Jimny stuff bolts in. You can use a Vitara steering box with an adapter So its a direct bolt up with the G16B with the jimny gear? nice!
How hard is it to put a J20A in , does it require a stronger transfer case. donor would be a 1.3L sierra Quite hard. You'l need to chop the trans tunnel out, make new engine mounts and all sorts of things like that. The Sierra transfer should live depending on your driving style. Why do you want a J20a? A G16b is a much easier and much more well trodden path. I was hoping there were a few build threads and kits made up on the J20A; obviously there isnt? I drove a 1.6 and 2L vitara and the 2L felt better to me; in torque and top end
also is a WT better? can you get hard canopies for them as well ? Depends what you want to do with it. Buy a NT if you want to do heaps of hardcore offroading so you can utilize the narrower spring spacing and fit WT diffs. Otherwise, buy a WT. Do not buy a coily if you want to mod stuff. Yes you can get canopies for them, they're a little rare these days though. So buy a Normal width track, mkay!
Now all I need to do is smash heads and get everything :peaceout:
Post Posted: Mon Oct 28, 2013 12:43 pm
Just to clarify. You can't use Jimny A/C in a sierra. Some Sierras have A/C so you use that.
A G16b goes very well in a Sierra. A J20a powered Sierra would fly. Sierras weigh a few hundred kilos less than Vits.
Post Posted: Mon Oct 28, 2013 12:54 pm
and if you search there is a whole thread in good tech about a J20a into a sierra. its been done and i loved it.
Users browsing this forum: No registered users and 37 guests
