It is currently Fri Sep 25, 2026 9:45 am
Vehicle: 91 tin top
Post Posted: Thu Nov 07, 2013 3:03 pm
So after a trip down to the Murray mouth and driving on a bit of a lean down the beach, the right rear wheel is covered with diff oil on the inside, and was dripping out by the time i stopped. Jacked it up when i got home and theres a bit of movement, so it'll need to be done. Whats the best way to do it? Genuine or just a bearing shop? Any part numbers to go off? Did try searching, but probably not well enough.
Chears
Post Posted: Thu Nov 07, 2013 3:14 pm
I just went to my bearing shop told them the car bang all done!
Vehicle: 85 ' Drover
Post Posted: Thu Nov 07, 2013 4:20 pm
You will need to press it on and off the axle though.
Post Posted: Thu Nov 07, 2013 4:26 pm
I cut the outer race off the bearing smashed the guts out of the bearing then slid the tin cover off
and the just knocked the rest off with a cold chisel.. (But I am a member of the RAG Engineering)
Vehicle: 91 tin top
Post Posted: Thu Nov 07, 2013 4:51 pm
no problem with doing it, have a press at work. Will try the bearing shop tomorrow, thanks
Post Posted: Thu Nov 07, 2013 4:55 pm
make sure you get japanese bearings, not cheap chinese shit
Post Posted: Thu Nov 07, 2013 6:24 pm
If you have access to NT rear axles you can remove the bearings and keep the spacer rings.
Fit them to your WT axles with new NT bearings and buy a box of beer with the savings over WT bearings.
Vehicle: 99 Grand Vitara
Post Posted: Fri Nov 08, 2013 7:47 pm
Is Koyo any good?
http://www.strictly4x4.com.au
Post Posted: Fri Nov 08, 2013 8:05 pm
yep Armsup
Users browsing this forum: No registered users and 35 guests
