https://auszookers.com/forum/
5 pin mechanic AFM
https://auszookers.com/forum/viewtopic.php?f=37&t=53505
Author:  TALLEN7 [ Mon Nov 07, 2016 9:50 pm ]
Post subject:  5 pin mechanic AFM
Hey everyone, have a g16b in my sierra, it's a new installation.
It won't idle at all unless I manipulate the cone style AFM, if I push it in about 3-4 mm it will idle and everything works great but
if I release it then it just dies!!
I would normally assume it's stuffed but was wondering if manipulating it could be masking the actual issue.
So if you know much about these things then it would be great to hear from you!!
Cheers, Tom!
Author:  Grags [ Tue Nov 22, 2016 6:26 pm ]
Post subject:  Re: 5 pin mechanic AFM
maybe you have some unmetered air coming in somewhere else like the crank case vent/pcv system has a problem or some other pipe or a split in the rubber bellows
or the plug connections are dirty, or a wire might be broken somewhere
At lease check them out before condemning the Air Flow Meter
