It is currently Wed Aug 12, 2026 11:41 pm
Vehicle: Suzuki Sierra
Post Posted: Sun Dec 04, 2016 7:28 pm
Hi guys, first post here and first Zook as well.
About a week ago I bought a 96' leaf sprung wide track modded Sierra.
While I'm over all very happy with it, there are a few things I could use advice on.
Firstly, it's had an engine conversion to an EFI Vitara 1.6 (I don't know the engine code, but I check if that's needed) but it is using the stock 5 speed Sierra gearbox.
This has caused what I'm told is a common issue with this swap, the clutch makes a bloody awfully loud vibration noise around 60 - 80 km/h.
The owner told me he had it investiaged by a mechanic and he believed it was caused by a tiny tolerance being out between the two, but that no damage is being caused.
Regardless, I want to use the Sierra as a daily, so I plan to fix this.
It has a XTD clutch in it at the moment, but I was looking at putting in an Exedy.
My question is, to fix this tolerance do I get a vitara or Sierra clutch, or is there more to it?
Second question; it has 31" inch Silverstone extremes on it, while very impressive off road, as I said before I'd like this to be my daily so I put some 29" a/ts off my feroza on it however the front left rim was rubbing when turning to the right on the steering knuckle.
Both are 15 inch rims, but the Silverstone are wider. I should also mention it has an aftermarket Superior Engineering chromly steering set up.
Any ideas here? I can report back with both exact sizes.
Last question I'll ask, I have more but don't want to ask too much in one thread...
Neither the stock water temp gauge or the aftermarket one it has read anything, even doing some pretty decent crawling it sits at the lowest.
Thanks for any help.
Vehicle: Vitara 1994
Post Posted: Sun Dec 04, 2016 8:44 pm
Did you change the wheels also when going down a size?
Post Posted: Mon Dec 05, 2016 5:32 am
This is not a common issue at all, in fact, I've never heard of it. Two of the four bell housing bolts align between Sierra and Vitara, so it's not possible to misalign the engine and gearbox. (if that's what the mechanic was referring to)
A vibration at a road speed (regardless of gear) is extremely unlikely to be associated with the clutch. Its most likely associated with the jackshaft, transfer case or rear driveshaft. My guess is the jackshaft universal joints need replacement.
If the vibration is associated with engine speed ( so not related to road speed or selected gear) , it could be associated with the input side of the gearbox. Dipping the clutch should make it disappear. Is it a fast "thrumming" type of vibration? does it make the gear lever and transfer level jiggle? Does it get worse with more torque (is in lower gears/more acceleration?)
This is a bit confusing. The rim and steering knuckle always move together as a unit, so if it's rubbing at right hand lock it's rubbing straight ahead. If in fact the contact is between the tie rod or drag link and the rim, that would be understandable. In this case, the feroza rims have incorrect offset to clear the bulkier superior tie rod/drag link.
Most likely was never connected/changed over when the new engine was fitted, but without photos/more detailed information I can't say more than that. You definitely want a gauge connected though, depending on how the cooling system was setup, overheating is possible and these motors are prone to crack if they get hot.
Post Posted: Mon Dec 05, 2016 4:55 pm
Thanks for the replies.
Here is more information.
Today's drive home I tested the vibration sound on the highway, and it does go away if I press the clutch (even 1/4 way in). It will also fade if I come off the throttle entirely. I don't think the speed is correlation, just when it happens most... Perhaps best described as happening under load. I have receipts from the previous owner for all the uni joints replaced a few months ago.
As for the wheels, my fault I referred to the wrong part. I guess it would be the tie rod ball joint? I will try to upload a picture.
The sizes are 215/80/15R for the feroza that rubs and the Silverstones are 31/10.5/15R (sorry about the imperial)
I had a look around the engine bay and there is a yellow wire running from the front of the thermostat. I will try to trace it will a circuit tester when I get a chance. The aftermarket gauge has a white wire running off the positive, but I can't see where it would be going in the engine bay.
Users browsing this forum: Google [Bot] and 58 guests
