It is currently Wed Aug 12, 2026 3:49 am
Vehicle: 93 Vitara 5 door
Post Posted: Sat Jan 07, 2017 7:39 pm
Hi all,
I've got a 93 LWB vit and I'm doing a 2" suspension lift and going run 235/75r15's. Is there any need or advantage to adding a 2" body lift to the list?
I'm living in brizzy and want to head over to the islands as well as some tracks up the sunshine coast. Can I get away with out the body lift?
Cheers[list=][/list]
Post Posted: Sat Jan 07, 2017 9:43 pm
Those tyres are under 29". You don't need a body lift.
But if you do decide you want one, I'm your man ;)
Post Posted: Mon Jan 09, 2017 10:56 am
Awesome. is there much to the 2" body lift. I've read that you can get away with just changing where the break lines are mounted? or will you have to extend a heap of other stuff as well?
Post Posted: Mon Jan 09, 2017 8:14 pm
It's all pretty easy. You do need to lift your bumpers and barwork
Vehicle: Vitara 1.6
Post Posted: Mon Jan 09, 2017 9:44 pm
You can also remove the front and rear lower bumper and leave it off for a while.
I have an auto and if was just the front brake line to worry about. (Eg rotate it)
Fuel filler hose needs unclamping and reclamping after the lift is done. There is enough overlap to cover the the hard pipe.
Post Posted: Tue Jan 10, 2017 6:44 am
Kit comes with instruction
Users browsing this forum: No registered users and 70 guests
