https://auszookers.com/forum/
Gearbox questions
https://auszookers.com/forum/viewtopic.php?f=37&t=53758
Author:  Darby [ Mon Jan 09, 2017 9:15 pm ]
Post subject:  Gearbox questions
Just wondering if a coily gearbox is any different to a "normal" 1.3 one?
Will I have any problems putting a "normal" one in my coily ?
Thanks in advance.
Author:  greenzook89 [ Mon Jan 09, 2017 9:17 pm ]
Post subject:  Re: Gearbox questions
AFAIK coily ones are the same. The only difference i can see externally is the coily doesnt have the hole for timing on the bellhousing.
Author:  Gwagensteve [ Tue Jan 10, 2017 5:53 am ]
So how do you time the motor if you have an non-coil g13?
Gear ratio is also different in 5th
Author:  greenzook89 [ Tue Jan 10, 2017 9:00 am ]
I thought the difference in 5th was NT to WT era Steve?
Author:  Gwagensteve [ Tue Jan 10, 2017 9:40 am ]
Not as far as I am aware. Coil was shorter due to the taller transfer ratios. I recall this from when the coil Sierras was released. As always, could be wrong though.
